Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Welded Front Clilp
Old 04-06-2002, 10:11 AM
Phat's Avatar
Phat Phat is offline
Toy builder
I will say this much. If the guy could not get the clip even on straight....throw the frame away or cut the clip off and start fresh. The measuring and welding is the easy part of the clip. To do a clip properly it must have a body on the car...with front fender.Look at the wheels in the wheel opening with the clip tacked. now blow it a part and finish weld it. Did you check to see if the track width was ok?? I really think its to wide for a 35 drum brakes are a little narrow but if you change to disc's its wider.(i could be wrong on this one cause i dont do clips anymore) get the old tape measure out..start fresh.
