Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Welded Front Clilp
Old 04-08-2002, 09:41 AM
beetle9's Avatar
beetle9 beetle9 is offline
Problem cured. I took Phat's advice and removed the clip. I did not cut it off however. I merely took my air cut off tool and cut off the old weld, loosened the clip up and squared it with the old ford frame. It is now within 1/8th of an inch from any measurement point. Now I will re-weld and shouldn't be any problem. I reinstalled the fron fenders and running boards on the frame and everything is centered. Life is now good again. Thanks Phat.
