Hey one more thing if you got that far.Get the rear end set to the height you need it. Now check the lower control arms to the ground...are they level(front to rear,tipped back a degree or so is ok but forward is a no no) Also the take the springs out and put a piece of threaded rod were the shocks go or weld straps on the lower a-frame to frame with the lower a-frame level side to side( center of ball joint lower than the inner pivot for the a-frame) That will tell you if the clip is on to low or to high for you . Good luck
