Welded rear differential??? - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 03-07-2005, 03:05 PM
chevyelc81's Avatar
How reliable is having a welded differential or a mini spool in a daily driven street car? Has anybody done this? Has there been any serious problems with anybody who has tried this? Thanks.
Old 03-07-2005, 03:23 PM
Elevinpointsixtoone's Avatar
Funny it seems like we just did this but here goes again....BAD, BAD, BAD, BAD, BAD !!!
Without the ability to "rachet" on the outside when going around corners you will be basically dragging one tire. You will tear up both sides but the left side will probably go first. And if you hit some moisture while going around a corner, hang on! Chances are you will spin out.
Locked spools are for drag racing only. Period...
Other side of the coin, my buddies 65 stang with a drag built 351, full cage..etc, etc, etc was loads of fun late saturday nights with its welded spool and all sideways through its first 3 gears. STUPID STUPD STUPID!
Old 03-07-2005, 03:40 PM
willys36@aol.com's Avatar
Wiki Edits: 21
PLEASE do a search on the board on this topic as you should with any basic topic like this. Has been discussed to death.
Old 03-07-2005, 04:14 PM
OddRodder's Avatar
CORNFED and INBRED !?!
When you do your search. pay extra attention to the stories from BOBCRMAN !! If I remember right, there was a crash and something about operating an unsafe vehicle and something about insurance NOT paying for any damages!!!
Old 03-07-2005, 08:39 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
This question coming from a member that has been a member since April of 2002.
Must not have been looking around lately.
Since this post topic has been discussed to death and a decent search will find the same answer written many times over I am closing this thread for a self explanatory reason.
Closed Thread
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
79 trans am rear discs busterbuddie Suspension - Brakes - Steering 7 01-20-2005 09:58 AM
replacing rear differential - what should I do? Johnny Bravo Transmission - Rearend 5 10-26-2002 10:19 PM
