Welder - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2007, 06:03 PM
52RodTruck's Avatar
Last journal entry: Pics
Welder
What is a good, inexpensive welder tp purchase to work on a vehicle. I am going to be welding in patch panels, and some other modifacations that require welding. I've done a small bit of welding before, but never owner one. Just looking for info from guys who weld more than I do. Thanks.
Old 01-11-2007, 07:51 PM
This subject has been covered a bunch of times. Do a search and your question should be answered.
Also check out weldingweb.com, hobartwelders.com and millerwelds.com. You can also search autobody101.com and autobodystore.com. They all have forums where you can search your answer.
The main thing is to stick with a name brand such as one of the big three, Lincoln, Miller or Hobart. They're all good.
For patch panels, a 110V welder such as a 135 mig will do fine. The problem is, as your skill gets better, you'll quickly outgrow the capabilities of a small 110V welder (It's amazing how many things need to be welded around the house and shop). The sage advice is to spend more if you can to get a 220V mig rather than buy twice.
But if all you are going to do is sheet metal, a 135 mig will work well. But if you want to motor mounts and such too, it is better to step up to a bigger unit.
Old 01-11-2007, 08:00 PM
You can find good deals on new in the box welders on ebay if you are patient. I would be leary of buying a used one off of ebay.
Places like Indianaoxygen.com have good prices as well.
Often your local welding store will make you a good deal if you haggle as they want you to come back for consumables.
Some people have had good luck with harbor freight for welders but I didn't. I learned the hard way before buying a Lincoln, hence my suggestion to stick with a name brand.
welder
I would go ahead a spend the extra money and buy a descend welder like a miller,lincoln,holbart. You can find them used at fair price and in the long run you will be glad you did, the quality of weld and the availability of parts will save you a headache in the long run.
Old 01-11-2007, 08:14 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
Lincoln is still made in USA, someone around here still has their industrial job.
Miller is made in Italy, not bad.
Hobart I hope is still made somewhere better than China, Mexico, or another sweatshop.
I hate to buy stuff based on where it's built but we have to support ourselves somehow (I believe through our fellow Americans, screw the lotto). If we don't support the economy of our Nation, then have the wars America has been through worth the human price? I'm just doing my part preserving what they're fightin' for.
Old 01-12-2007, 08:58 PM
I have a 110v Hobart with sheilding gas. The hobart works EXCELLENT. I bought it at a local welding supply shop. I use it mainly for my resto work on my 62, but it will weld 1/4 with a single pass. I have $675 into the whole thing. Welder,cart and tank. I would have bought a 220v mig but I have an OLD lincoln duece and a quarter that rocks when you realy have to penatrate some steel. I also recommend to buy a WELL known brand welder. If you do you will have it for years to come.
Dennis
Old 02-11-2007, 10:18 PM
Nhrafan26's Avatar
Don't know if there was ever a post about this or not but I thought about it while reading through this one.
Does anyone have a MIG welder that does NOT have a wire feed knob and a heat setting knob on it?
An example of what would be in it's place are 2 different knobs:
Knob 1 Has settings for: Off, Steel, Aluminum
Knob 2 Has settings for: Weld, Spot, Stitch
Then there is a small adjusting knob on the MIG gun that turns up your heat AND speed in proper proportion every time.
I am looking to buy one of these types of welders.
I have looked at all the welders manufactured by Hobart, Lincoln and Miller and none of them have any such thing.
I know they exist (or at least did years ago) from the one that I used where I used to work. I looked up that company and they are no longer in business, but I do know it came from Canada.... any help from our friends to the North on this one????
Any help or leads are greatly appreciated more than you know!!
Old 02-11-2007, 10:38 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I don't have a clue about that one..I can tell you though that I have owned a Lincoln for over ten years and it has given me good service..
I find that having the infinite adjustments of wire speed and heat help a lot when welding sheet metal to get the bead "just right"
Just my take..
Sam
Old 02-12-2007, 08:33 AM
That may seem to be a good idea making it easier to make adjustments but then maybe not since they are apparently gone. I find machine located controls to be an annoyance but not really a problem, most of the time anyway. On the larger Lincoln welders we used remote current controls because some times the welder would be located a good distance from the feeder and going back to the machine to make an adjustment would be a problem so this does exist on the industrial machines anyway. Making a current adjustment at the machine was a bit annoying when it was on the ground and I was 300' in the air on the end of a dragline boom
Old 02-12-2007, 10:58 AM
tmeyer's Avatar
Go With A high end 220 volt Name Brand Welder
I can give you my experience with mig welders. I bought a 175 lincoln 220v mig. Used it for a year. It seemed to weld OK. I then upgraded to a Millermatic 210. The difference is like night and day. It welds soooo much better then the 175 does. I don't think it is the brand that made the difference, I believe it is due to the welder being a higher end unit then the one I had before. It is a big difference in price but very much worth it to me since I use it almost every day. Just my experience and opinion. I hope this helps.
Old 02-12-2007, 11:10 AM
tmeyer, Careful now you are going to hurt my feelings Just joking, I have been a Lincoln fan for many years and they have been really good to me they have been dependable as can be and did anything I have ever needed. However what you are saying is what usually comes up in these discussions so there must be a good reason for that and that reason is that Miller is a fine outfit! I have used a Miller 210 and it is just as you say about as smooth welding as one could hope for and although brand loyalty is strong here for me I find it extremely hard to find anything negative to say about that Miller, or most any Miller for that matter.
Welder problem - I think Ripped Body - Exterior 18 02-11-2007 08:41 AM
is this welder any good?? michiganjoe Body - Exterior 10 11-23-2006 07:57 AM
Anyone Welder shopping? Bruckmans Auto Garage - Tools 7 07-06-2006 02:01 PM
My first post and a welder question Bugs Garage - Tools 17 11-08-2005 02:49 AM
Arc welder ~VS~ Mig Welder ChrisMiddleron Electrical 15 07-08-2003 07:31 AM
