Welder capabilities - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2005, 01:32 PM
Welder capabilities
I recently aquired an older 230V LINDE stick welder. I don't hear much about this brand and I was wondering what its capabilites are. Could I use it to weld a frame?
Old 08-16-2005, 03:50 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
You could weld frames with it if it has high enough output amps. Do you know what size welder it is amp wise?
Old 08-17-2005, 07:05 AM
It has HIGH and LOW jacks( I guess there called jacks - it is where the welding leads plug into) on it. The HIGH output setting says 59amps @ 230Volts. It also has infinite volt adjustment that appears to relate to duty cycle so I'm guessing that to increase duty cylcle I must lower the volts which also lowers the amps????
Old 08-17-2005, 08:29 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Linde used to be a great welder. You'll know as soon as you start welding. It should be MORE than enough for a frame. Grab a couple scraps of 1/4" plate to practice on. If you can burn through them, you know you got PLENTY.
Mastercraft Mig welder? Canadians eh montea Garage - Tools 19 01-23-2007 11:24 AM
is this welder any good?? michiganjoe Body - Exterior 10 11-23-2006 07:57 AM
Hobart Champion 4500 welder sotxpanrider Garage - Tools 2 03-06-2005 09:07 AM
Seeking MIG welder recommendations Slipangle Garage - Tools 6 10-20-2004 09:04 PM
Arc welder ~VS~ Mig Welder ChrisMiddleron Electrical 15 07-08-2003 07:31 AM
