Welder problem - I think - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-10-2007, 08:31 PM
captmetal's Avatar
i have a 110v lincoln a great welder but if i used it a lot it does the same thing , i learned that the transformer inside are just getting overheated and it seems to reduce the power, it takes a long time for it cool off, usally i wait till the next day to finish, or if i can i take breaks before it heats up.
  #17 (permalink)
Old 02-10-2007, 09:07 PM
Thats what happens when the duty cycle is exceeded or some machines just shut off, an extension cord can make this problem even worse. Make sure the wiring is up to par and if an extension cord is used it must be sufficient in size to carry the current. If the wiring is in order I have seen the problem helped, but not eliminated by adding a fan to the welder case to help cool the transformer, a fan is not always used from the factory on some cheaper outfits and these always benefit from the addition of one. Even welders that are already cooled can usually benefit from the addition of a larger fan. This may not be a practical thing to do in every case but it is something to be considered.
  #18 (permalink)
Old 02-11-2007, 08:42 AM
adtkart@aol.com
To expand on what Red said, it's a good idea to blow the machine out every once in a while also. I don't know of many garages that don't have dust, and it likes to collect in any type of machinery, specially stuff that operates on electricity. If there is a fan in there, it will suck up more dust than a shop vac.
Aaron
  #19 (permalink)
Old 02-11-2007, 09:41 AM
Adtkart, You bet that makes a difference! I blow out my welders regularly and even if it has only been a day or so there usually is quite a bit of junk comes out of there. I had a fellow bring his little Hobart over because it would overheat almost as soon as he started welding and when blowing it out did not help we opened the case, it had a large mouse nest almost completely surrounding the transformer! We removed that mess and the problem disappeared
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 11:00 PM
Anyone Welder shopping? Bruckmans Auto Garage - Tools 7 07-06-2006 03:01 PM
My first post and a welder question Bugs Garage - Tools 17 11-08-2005 03:49 AM
*&%##*^#!! starter problem solved!!!! 85 vette Engine 12 02-22-2005 09:12 AM
Welder problems... 86GMC Garage - Tools 10 01-17-2005 06:23 PM
