Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Welder problem - I think
Old 12-15-2006, 01:36 PM
Jake_Dragon's Avatar
Jake_Dragon Jake_Dragon is offline
Last journal entry: New Carb
Originally Posted by weirdbeard
NO. jk. I looked but could not find where I read that. Dangit! It had something to do with certain types of blasting media impregnating in mild steel and causing weld failure.... I think.. I googled and only found lot of people USING sandblasting to clean metal to be welded. Just ignore me. I am confused.
The sand will contaminate the steel and make it hard to weld. You need to grind the metal till its shiny.
