Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Welder problem - I think
Old 12-15-2006, 04:30 PM
oldred oldred is offline
Silica embedded in the metal surface. It does not seem to be much of a problem on thick stock but on something as thin as body panels it probably is not a good idea, however it is easy to remove so if you clean it good before welding it should not be a problem.
