welder problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2011, 08:26 AM
welder problems
wire feds gas feeds but no weld spark
Old 10-04-2011, 10:31 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Welcome to the board.. please post your question in the garage/tools forum and some more details please..
Thanks
Sam
Old 10-04-2011, 04:36 PM
jonahb's Avatar
What kind of model welder do you have? Check your drive rolls if they are spinning then you need to set the tension and/or check the individual drive roll to see if might be the wrong one like a 0.035 trying to push 0.023 wire. Did you check your whip for kinks or "knots" they need to be fairly straight on a small welder. Last but not least depending on the welder check to make sure all electrical connections are tight and no broken wires.
Old 10-06-2011, 02:23 AM
327NUT's Avatar
Your wire feeds, your gas feeds but no weld spark, first thing I would do is make sure your ground cable is not corroded and tight at both ends......mig's HAVE to have a good ground. If thats not it a call to the mfg. might help.
Old 10-06-2011, 09:31 AM
Looks as if this fellow may be a "hit-and-run" but something I have seen guys literally pull their hair out over, and I have seen this happen several times, is the ground cable losing contact to the ground clamp. They are sure the ground clamp is solidly attached to the work piece but still no arc, even trying to weld directly to the clamp itself brings no spark! I remember one case in particular where one of the guys had taken the welder apart and had an electrician testing the board circuits trying to determine why there was no welding current, they were testing for current by feeding the wire directly onto the ground clamp. The lug where the cable attached to the clamp had lost contact and while the cable was electrically "hot" the clamp was not! When trying to determine the cause of no welding current always check the cables themselves first and don't just assume the ground clamp or rod holder is in full contact with the cable, these things sometimes get hot and over time can form a non-conductive scale causing the cable to become insulated from the clamp.
Old 10-06-2011, 12:05 PM
327NUT's Avatar
????? like I said, "make sure your ground cable is not corroded and tight on both ends"
Old 10-06-2011, 12:14 PM
Welder Problems
It is a Clarke 185SG mig with spool gun
Old 10-06-2011, 12:23 PM
Wiki Edits: 3
there could be corrosion or loose connections anywhere..Spool guns can be touchy..have you replaced tip as a worn tip may be the culprit here..If all else fails then we go to the continuity tester in an effort to isolate the problem..
Sam
Old 10-06-2011, 05:22 PM
So you did and I completely overlooked it!
Old 10-06-2011, 08:42 PM
hp246's Avatar
1. As already stated check you ground and cable. 2. Check all of your connections. 3. Make sure you have proper polarity.
Old 10-07-2011, 01:15 AM
327NUT's Avatar
Hey, here's a thought....check your ground cable for corrossion and tightness!!!!
Old 10-17-2011, 08:13 PM
Richiehd's Avatar
JS-70
So what Kind of welder is it? Im guessing it needs a circuit board. Just put one in my Snap On welder. Feeds, Gas, no spark, Ah, checjk the grounds!
Old 10-18-2011, 07:01 AM
Old Fool's Avatar
I have found the ground wire has broke inside of its insulation. Use an ohm meter and test it from machine connection to clamp.
Old 10-18-2011, 07:02 AM
Old Fool's Avatar
he posted the above
miller welder problems bet on black Garage - Tools 14 08-08-2008 09:39 PM
Old Welder Papat Introduce Yourself 2 07-25-2007 02:02 AM
What welder should I use?a KFXrider88 Body - Exterior 9 07-05-2006 01:19 AM
Welder problems Derkyb Garage - Tools 6 02-19-2006 08:28 AM
Welder problems... 86GMC Garage - Tools 10 01-17-2005 06:23 PM
