Welder problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2014, 08:09 AM
Wocha's Avatar
Welder problems
I recently bought a Sealey Professional 230V 100A No-Gas Mig Welder to do some body repairs. I have used gas and stick welding in the past but not MIG. I bought the welder because a: it is low power (it only has two power settings Min and Max) and b: it was cheap (mistake!!). The problem I am having is that it is blowing holes through the panels even when on the Min setting and very quick stitch welding. I am using .9mm wire which is the only wire it will take. Would better quality wire help? I live in Spain but can get items from most places it Europe. Any suggestions?.
Old 07-04-2014, 08:27 AM
Last journal entry: New Rev wheels and BFG KDW II tires
.9mm wire converts to .035" which should be an ok size for what you are doing. Having only two heat settings for bodywork isn't ideal but you use what you have to work with.
When you mention stitch welding, how much are you welding at a time?
Can you do a small tack without it burning through?
When doing light body panels it is best to only tack weld in different areas at a time. This way it keeps the heat from building up which warps the metal. Stop if the panel gets too warm too touch. Patience is key here and is worth taking your time. You will benefit with less work in the end.
One trick when tacking is to start with the wire on one side of the metal and not directly over the seam. This gives the filler wire a base to start on instead of blowing through the seam. Check to make sure the metal is fusing onto both pieces.
The same applies when you grind the weld down. Move around and make sure you aren't heating up an area too much. Stop right away if you see the metal start to blue or change colors when you are grinding.
The Following User Says Thank You to 64SS327 For This Useful Post:
Wocha (07-04-2014)
Old 07-04-2014, 08:42 AM
Wocha's Avatar
Thanks for the tips. When stitching it is literally as fast as I can. On then off almost immediately. Even then it will blow through sometimes. I am wondering if there is a problem with the welder.
Old 07-04-2014, 08:51 AM
Don't tack more than a couple times in one spot. Slow down and move around making sure the metal doesn't get too hot. This is the key to using a mig on thin sheet metal.
The thin metal can't dissipate the heat fast enough and that is why it is blowing through when you weld too much in one spot. The panel will warp if you weld it too fast and get it too hot. Sometimes a panel can get warped to the point where it can't be saved. It's worth taking your time or you will be creating more work for yourself in the end.
Wocha (07-04-2014)
Old 07-04-2014, 09:10 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Takes a lot of practice to weld body metal and even with that you will have a blow through on occasion.. Personally I like to start guys out welding with OA as that is more controllable and on that body metal we use an 0 size tip and 0.23 mig wire for rod..
Sam
Old 07-04-2014, 10:01 AM
Is that a flux core welder?
Old 07-04-2014, 10:03 AM
Wocha's Avatar
Yes it is a flux core gas less welder
Old 07-04-2014, 10:51 AM
Cool Willys!
Old 07-04-2014, 11:20 AM
Wocha's Avatar
Cool Willys!
It's 1942 Ford GPW
Old 07-04-2014, 11:35 AM
If you back off a little creating more resistance you may not burn thru so face.
Old 07-04-2014, 12:16 PM
Wiki Edits: 27
copper back up
They sell a copper back up spoon or you can flatten out a piece of copper pipe to match the contour of your project. The copper can help on the burn thru and it will absorb some of your excess heat.
http://www.ebay.com/sch/sis.html?_nk...ES+AND+PATCHES
.With flux core you should probably use a wire wheel on a hand held grinder to buff off all the flux-slag before starting your secont series of tacks.
A good welding source is welding tricks and tips. Jody usually posts a FREE new welding video each week.
http://www.weldingtipsandtricks.com/
Old 07-04-2014, 03:07 PM
ericnova72's Avatar
More for Less Racer
Any chance your welder will accept a MIG gas conversion, so you don't have to use that awful flux core wire??
Flux core doesn't do well on body thickness material, as you have found.
A couple pound chunk of copper as a back-up/ heat sink can help, as has been mentioned.
Old 07-04-2014, 06:07 PM
mitmaks's Avatar
Last journal entry: Grille
If you could reduce heat then you won't have blowthrough, I would get gas bottle, never had good results with gasless MIG welders.
Old 07-04-2014, 08:26 PM
I have to admit, life is too short, flux wire feeds are for welding fences in the wind.
Old 07-05-2014, 12:41 AM
MIG=metal inert gas
gasless 'MIG' welding is kind of an oxymoron
welding
welder problems Signdoggy Garage - Tools 13 10-18-2011 07:02 AM
miller welder problems bet on black Garage - Tools 14 08-08-2008 09:39 PM
Welder problems Derkyb Garage - Tools 6 02-19-2006 08:28 AM
Welder problems... 86GMC Garage - Tools 10 01-17-2005 06:23 PM
Arc welder ~VS~ Mig Welder ChrisMiddleron Electrical 15 07-08-2003 08:31 AM
