Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Welder question
Thread: Welder question
Old 12-19-2009, 04:11 PM
matt167 matt167 is online now
Wiki Edits: 31
you should not build a frame with a 110V MIG. they cannot provide the amperage and without proper pre heat, penetration will suffer.. possible to 'get it right' if your a decent welder, but it's not practice that should really be suggested.. 110V Arc will create a far stronger weld for somthing like a frame when comparing to a 110v MIG.. yea it won't look as good as a Mig weld, but not all pretty welds are strong...
