Welder for welding body panel. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-13-2008, 09:26 PM
[QUOTE=Rambo_The_Dog]For welding sheet metal - I do prefer the 110v, the 220v even on the lowest setting is a little more difficult to weld sheet metal with in comparision.
For maximum versatility though a 220v gives you more options for welding heavier stock.
As mike mentioned the welding method makes a difference and you can also use a copper sheet directly behind the weld to help burn thru issues and heat dissapation and there are also compounds that help prevent warpage like this stuff I got from Eastwood.
[That Eastwood stuff sorta reminds me of the old days when we used wet rags to keep the heat down and prevent warpage when brazing a piece of sheet metal. Thank God for MIG welders for this job, it sure makes a difficult job a lot easier. Oh BTW, we finished by using lead and not bondo and some of the stuff we did then is still around.
  #17 (permalink)
Old 07-13-2008, 11:11 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Originally Posted by UtahAdventureGuide
I'm replacing the rear quarter panel..........
What do you recommend?
Thanks
Lincoln 140c
.025 wire
75% Argon, 25% Co2 gas.
IMO the most bang for the buck.
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Repair of large dents in roof? rlackey Body - Exterior 9 01-28-2005 10:36 PM
my doors got stretched nomad57ry Body - Exterior 17 12-02-2004 06:51 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
