Welder Wiring - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-08-2011, 09:30 AM
I have a Lincoln 180T and am going to run a circuit for it this winter. Attached are the installation specs. If I interpret this correctly I should use #8 wire with a 40A breaker. Correct?
  #17 (permalink)
Old 12-08-2011, 09:55 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i (think) that is correct, you might consider/need larger wire if the cord is going to be extra long
i'm using 6ga wire (for the 2 power wires) and a 4ga (on the ground wire), for my cord, its about 35 ft long and i havnt had any problems running my miller 211
  #18 (permalink)
Old 12-08-2011, 06:58 PM
Wiki Edits: 27
wire size
The elect code has limits on how long your feeder wires can be before you need to upsize. I was right on the limit on length in my old shop and the lights would dim when someone was welding and the shop air compressor kicked on.
DIY TIG Welder 59Spitfire Garage - Tools 3 12-14-2007 06:11 PM
Welder wiring questions zimaad Garage - Tools 1 01-08-2007 11:22 PM
Welder help!!!! bigjoe Garage - Tools 15 08-02-2006 03:47 PM
220 wiring for welder cboy Garage - Tools 25 02-22-2005 03:07 PM
welder mattoxcw Garage - Tools 7 02-16-2004 04:19 PM
