Welders - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-06-2006, 11:23 PM
39Chevy,
If you will settle for the T version, keep watching Ebay. There's a bunch on there. I just won a bid three days ago on one, new in an unopened box for $409 plus $49 shipping, $458 total from an established seller with a 100% rating. The cheapest locally I could find one was $600 plus tax (though I didn't look real hard).
It seems that the Plus versions are no cheaper than local sources, maybe because they are pretty scarce on Ebay.
At least you are going with a name brand. I started with a HF mig several years ago and it has already died after light use. Never again.
  #17 (permalink)
Old 12-11-2006, 12:59 PM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
If you just buy a cheap helmet with one lense, you want a #9 or #10. That's good for most welding jobs.
The only time I've had a problem with my auto darkening helmet (provided by USAF -- forget the manufacturer and model) is when I was instructing. Lots of on/off cycles when watching over students shoulders will give you a head ache by the end of the day! If you use it a lot for a day or two you might get a bit of a head ache -- especially "stitch welding" large seams.
You can cut down on the headaches closing your eyes momentarily (a bit longer than a quick blink) right as the shield changes from dark to light (and vice-versa), which almost defeats the purpose of buying one anyway! Hard to anticipate when the arc is going to light up though. It's still better than having to reach up and move the helmet or using the "nod" tehcnique to lower the helmet -- you never move your head so you're still "on target" when you start.
My theory is your eyes are more ready to adjust when you close them momentarily, it's not the sudden adjustment like when you strike the arc. Learned this in the desert mostly -- going from a nice shaded room into very bright desert light.
  #18 (permalink)
Old 12-12-2006, 09:57 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
I just last week bought a new Miller 180 mig. It has just been released to the market and is not on the Miller web site yet. I bought it off Ebay from Indiana Oxegen. The thing about the new 180 is the voltage setting instead of having just 4 clicks to set it on it has knob just like the wire speed so you can dial in the exact voltage you need. I really like it. Here is a link to the company. The new Miller is not on Ebay you will have to call and ask about it.
http://stores.ebay.com/Welding-Suppl...QQftidZ2QQtZkm
It was $742.00 delivered to the door.
  #19 (permalink)
Old 12-16-2006, 01:41 PM
I have a 66 Mustang that I need to weld rear subframe patches on. I only have 110 available in my garage. Is it possible to get a safe repair with a 110 welder, or should I get someone to weld those pieces for me?
I haven't bought a welder yet for my body repair, and I am new to the welding stuff.
Thanks,
Eric
  #20 (permalink)
Old 12-16-2006, 03:17 PM
boatbob2
welders
hi,i have a lincoln weld-pac 155,8 years old,great machine,ive used hobarts,and millers,and they are all great machines. you pays your money and you takes your choice. before you buy,go to a few pawn shops and see what they have, my lincoln was $636.00 in home depot,and i bought one BRAND new from a pawn shop for $250.00 check out the pawn shops..im boatbob2
  #21 (permalink)
Old 12-16-2006, 05:06 PM
Eric, A 110 volt MIG will work just fine for what you are doing but stay away from the gas-less flux core welders. A lot of guys will buy a flux core welder because it is cheaper and up grade it to MIG later but it is much better and cheaper to just get a MIG in the first place. A 110 machine will do the job with .023 solid wire just like a 220 volt on thin stock but it's duty cycle will be shorter, that is you will only be able to weld a short time before having to let the machine cool however this is usually not much of a problem when doing body work. What you are planing on doing is not particularly hard but does require a fair amount of skill so if you do this yourself practice a LOT before attempting a job like that, learn to weld on scrap NOT on your car!
  #22 (permalink)
Old 12-24-2006, 08:33 AM
ccb ccb is offline
lincoln welder
lowes has the 175 for less than $500. lincoln rep told me they are the same machine on the inside as what is available from lincoln direct.
  #23 (permalink)
Old 12-24-2006, 01:33 PM
welding
Yeah I bought my Hood At Harbour Freight . Paid 650 On my Lincoln + the Bottle Small Argon Co2 Mix rann 100 Buck's ! Your Lincoln Can Weld with Flux Wire and or Argon Mix Gas in a Bottle Reverse Polarity you can run Flux wire with out the Argon Bottle I Prefer the Argon Mix with .06mm Wire and or .08mm Wire Untill Metal Get's Thicker than 1/4 in or 3//16's is about where Penetration needs Flux Wire welding . My welder I run on 220 amp's << You need too check where and how your Gonna set Up 110 Or 220 Out lett Cause may Require a 220 Breaker And Wireing And Not Sure on this But Even the Lincoln Set upp on 110 Amp's I Think Requires A Single Circuit Breaker on 8 Gauge wire with a 20 amp breaker ! << Meaning Nothin can runn on the 110 Breaker Except the Welder and it has too come off a 20 amp breaker and wire gauge needs too be big enough too handle the 20 amp breaker and 20 amp out lett . So I urge you afore Buying the Welder that You Look at your Breaker Box and Determine if your sett up for running a welder and or what your willing too do or go thru too sett up the electric on your welder . <<< almost same deal as an Air Compressor ! So what ever Building Garage Etc Your setting up too weld in or do work in needs Some investigateing intoo ! Preferably before you purchase the Welder and or Air Compressor . As my Welder is sett up in my Dad's Garage . Wich he had wired for a 220 amp welder when he built the house ! But He Put Plug in on the Back Wall <<< Means I got a 15 ft extension Cord Too Welder So I can reach out front of the Garage . Extension Cord Rann me another 120 Buck's Built it My self with Wire From Home Depo About as Big around As your Thumb or Bigger and a Box Plugg In Of Proper Gauge wire . But reall screw up was the 110 Amp Compressor All outletts in the Garage were runn off 15 Amp Out letts and or breaker ! Luckily I traced Wire From the Fuse Box and Determined it was of a Large enought Gauge wire too Runn a 20 Amp Breaker . << Means I got Lucky and wire was of Large enough grade wire I could Runn a 20 Amp breaker and out lett For the Compressor ! << Sounds Complicated ! But it's Not ! Start At Breaker Box Make freinds with Guy at your Local Hardware Store . Investigate what you need then determine if your Gonna go 110 Amp's and or 220 Amp's And How your Gonna do your Compressor . << Will need 2 Seperate wires and 20 amp breakers on single seperate out letts . Other wise every time you turn the lights on the Welder and or Compressor Etc Or any thing else plugged in on there circuit will trip the breaker ! <<< Hope this help's gett ya pointed in right Direction too makin a Good Viable Descision on your Purchase ! Safety Glasses <<< Gonna need um and Suggest you wear them ! Im Currently Sufferin an Eye Injury ! Again ! 25+ years of metal workin ! Cant take it back ! once it happens ! Hurts reall badd ! And like any thing no matter how safe you are ? After 25+ years of daily metal fabricateing and welding it's bound too bite you a few times . << Only takes gettin bitt once, and it's not worth it ! Be Safe ! Shopp around ! Investigate ! Ask lotts of stupid question's ! Now I gotta take a Vicodan and a Napp, my eye hurts . Merry Xmass. Hope your's is Better than Mine ! Safety , Safety, Safety ! Big Ouch ! Lott's Of Anger ! And Regrett ! Sean
  #24 (permalink)
Old 12-25-2006, 12:04 AM
I believe you are talking about 110 volts and 220 volts, not amps? I believe you might be a little mixed up.
gcrmcc
  #25 (permalink)
Old 12-25-2006, 10:19 AM
You could turn a compressor pump big enough to run a wind tunnel with that 110 AMP motor
  #26 (permalink)
Old 12-31-2006, 01:17 AM
PRO 48 fleetline's Avatar
Last journal entry: Csr Electric Water pump
i recently just bought a 140 Hobart my first welder and im really happy with it bought it to worl on my hot rod and so far seems to work great i paid 490 for it its a 115 plug and can use the flux and the gas look forward to working with it just got it the other day plus i got the dealer to trow in a nice helment and a big role of wire with tank around 600 even
For us old welders oldred Garage - Tools 12 09-22-2008 07:06 PM
HTP Welders Question for Toyman Bugs Garage - Tools 19 03-15-2006 02:19 PM
Welders mike bryan General Rodding Tech 12 01-22-2004 11:33 AM
welders and plasma cutters casper455 General Rodding Tech 7 12-18-2003 10:58 PM
Low end mig welders? Slickriffs Body - Exterior 19 08-05-2003 07:19 PM
