welding - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2007, 07:45 PM
smoke's Avatar
welding
Can you weld cromemoly to steel? Also can you mig weld it or do you need to tig it? If so what gas would you use and wire?
Thank you
Old 02-15-2007, 07:52 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Yes you can weld Chrome molly to steel. Yes you can mig weld steel. Use argon /c02 mix.
Old 02-15-2007, 08:29 PM
It's done all the time, ER70S-2 wire is good for welding CM such as 4130, also E8018-B2 if you use stick. These are just suggestions and are by no means the only wire/rod you can use. C25 gas for the MIG. How thick is the material you are welding? Tube maybe?
Welding info Kevin45 Body - Exterior 10 08-26-2011 08:09 AM
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 29 06-18-2009 06:54 AM
welder reccomendations? rally4x4racer Garage - Tools 32 10-14-2008 09:00 PM
Parasol Metal body filler. x711 Body - Exterior 16 02-14-2006 09:47 AM
Welding Books Magnus_Jager General Rodding Tech 6 11-29-2005 03:57 PM
