welding - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2007, 12:13 AM
brian berwick's Avatar
welding
what should wire speed and gas be set for when welding mild steel or sheet metal
I got a 110 volt MIG been told a few different things Iv always had shielded wire or arc ?
Old 05-24-2007, 01:10 AM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
Not only does Miller sell some of the better equipment - they have a really nice website...
try these links for general recommendations - I always run test beads on a piece of like thickness and material that I am welding to dial it in first...
This is a neat calculator where you specify the type of metal and thickness and then it automagically displays recommendations on speed and heat settings.
Miller Solid Core Welding Calculator
This is a link to some general welding tips - there is a ton more information available to the average welder out there in their support section besides these 2 links
Good luck!
Miller Welding Tips and Tricks
Old 05-24-2007, 05:01 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
On my Lincoln there is a chart inside the door that gives a list of settings for various thickness of metal showing wire size, feed rate and heat settings..I find it fairly close for most things I do..Once you get some time in welding you will find that you may need to do a bit of fine tuning to get the desired results..and a lot of it is just running bead until you get the hang of it..
Sam
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Welding info Kevin45 Body - Exterior 10 08-26-2011 08:09 AM
welder reccomendations? rally4x4racer Garage - Tools 32 10-14-2008 09:00 PM
Parasol Metal body filler. x711 Body - Exterior 16 02-14-2006 09:47 AM
Got a welding coach cboy General Rodding Tech 61 10-28-2005 09:03 AM
