-   -   welding a 700r4 bell housing (http://www.hotrodders.com/forum/welding-700r4-bell-housing-217381.html)
nskeeter99 03-26-2012 09:10 PM
I have an 81 Datsun 4x4 with a 350 and 700. my tcas is divorced. With that being said tonight my drive shaft bolts broke loose the the short d shaft. the tcase breaking it and the bell housing on the 700. I found a few post on here about wielding but they were all cracks. I just spent 1600 having this thing build and hate to lose it. So can i weld the housing back and it hold as well as a stock tranny would?
mmerlinn 03-27-2012 03:16 AM
Unless you get it lined up perfectly, and you have a perfect weld, you are most likely to wind up with a pile of trash.
Better to recase your transmission.
nskeeter99 03-27-2012 05:11 AM
if it get welded i wont do it it will be take to a pro.
S10xGN 03-27-2012 09:24 AM
If any of the welds are to be made in areas that have been machined, forget it and buy a new case. If it's just the bell, go for it...
Russ
learning2fixz 03-27-2012 10:56 AM
wielding 700r
Hello, i had a 700r welded, on the bell housing, and it worked fine, i had the trany shipped to me, and when i got it, the ear was broke off, rite where the bolt hole lined up with the block, cost me 50.00. I did have a little problem tho, The weld was in the way just a bit, so it made it hard to tighten it down, but you could do it...lol. it worked great..good luck and have a great day...
If it helps, i have picture of it being wielded....
nskeeter99 03-27-2012 05:41 PM
thanks guys i called a couple of welders and they said for the time it would be 150 to 200. the tranny shop that did my rebuild told me they would swap my good parts to my spare case for 250 so i thing thats my best option.
nskeeter99 03-27-2012 08:14 PM
scratch early reply. just came across ultra bell for the 200 I think that might be my best go.
