welding a 700r4 bell housing - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2012, 09:10 PM
I have an 81 Datsun 4x4 with a 350 and 700. my tcas is divorced. With that being said tonight my drive shaft bolts broke loose the the short d shaft. the tcase breaking it and the bell housing on the 700. I found a few post on here about wielding but they were all cracks. I just spent 1600 having this thing build and hate to lose it. So can i weld the housing back and it hold as well as a stock tranny would?
Old 03-27-2012, 03:16 AM
Wiki Edits: 85
Unless you get it lined up perfectly, and you have a perfect weld, you are most likely to wind up with a pile of trash.
Better to recase your transmission.
Old 03-27-2012, 05:11 AM
if it get welded i wont do it it will be take to a pro.
Old 03-27-2012, 09:24 AM
S10xGN's Avatar
Gotta love a turbo!
If any of the welds are to be made in areas that have been machined, forget it and buy a new case. If it's just the bell, go for it...
Russ
Old 03-27-2012, 10:56 AM
wielding 700r
Hello, i had a 700r welded, on the bell housing, and it worked fine, i had the trany shipped to me, and when i got it, the ear was broke off, rite where the bolt hole lined up with the block, cost me 50.00. I did have a little problem tho, The weld was in the way just a bit, so it made it hard to tighten it down, but you could do it...lol. it worked great..good luck and have a great day...
If it helps, i have picture of it being wielded....
Old 03-27-2012, 05:41 PM
thanks guys i called a couple of welders and they said for the time it would be 150 to 200. the tranny shop that did my rebuild told me they would swap my good parts to my spare case for 250 so i thing thats my best option.
Old 03-27-2012, 08:14 PM
scratch early reply. just came across ultra bell for the 200 I think that might be my best go.
bell housing Hammerhand Transmission - Rearend 3 03-13-2011 09:50 AM
Dodge poly bell housing; what manual transmissions fit the bell housing? Hemi-Meadowbrook Transmission - Rearend 2 03-08-2011 08:07 PM
Small bell housing 700r4 eliotmansfield Transmission - Rearend 2 07-26-2007 08:12 PM
Bell housing JAFO Engine 1 10-05-2002 03:27 AM
Bell Housing jfees21 Transmission - Rearend 2 03-27-2002 08:19 AM
