Welding Axle Tubes to the Housing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2011, 11:09 PM
Sixshooter45's Avatar
I picked up a 8.8 Rear out of a 93 explorer. It will be going in my 53 chevy. I am wondering if I should weld the axle tubes to the housing, or if it is unnecessary? Any recommendations?
Thanks
Old 08-16-2011, 11:44 PM
first make sure its gonna fit ? 53 car or truck ? measure your 53 rear end backing plate to backing plate where the drum brakes are, most folks do it inside like 55 inches or so ? then i am betting the ford had coil springs and you have leaf springs ? have to weld on spring purches and set your pinion angel ? then have axles fixed for chevy bolt pattern ? it can be done ? but wont be cheap !!! you might be better off with like a 10 bolt out of nova or something ? its up to you ? good luck !!!!!!! and even with the nova rear end you'll need to weld on spring purches to the housing like 20-30 bucks a pair and set you pinion angle your allowed 7 degress difference or it will eat u-joints up !!!!!!! you'll need a unversal pro tractor for this, tool about 10 bucks at sears ? round guage with a flat spot on one side shows you degress !!!
Old 08-16-2011, 11:51 PM
Explorer rears are a perfect fit for 49-54 chevy cars. 1/2 inch narrower than stock at 59.5". And I am getting different leaf springs so all thats needed is to cut off old leaf spring perches, reweld new ones, and voila! And it doesn't bother me to have a ford bolt pattern as I will be using different size wheels on the rear. Plus they come with 3.73's, 31 spline, and posi's.
I just know some high HP guys weld the tubes, just not sure if I should or just leave 'em be.
Old 08-16-2011, 11:55 PM
its up to you !!!!
Old 08-17-2011, 12:39 AM
SSedan64's Avatar
If you're gonna be Drag racing= Hard lauches w/slicks, weld them, if not it wont be needed.
welding on a G.M. diff. housing. jcarter Suspension - Brakes - Steering 13 12-12-2009 09:05 PM
welding axle tubes 8.8 and pads tomthecomic Transmission - Rearend 1 01-20-2008 12:44 AM
welding brackets on housing cboy Transmission - Rearend 13 11-06-2004 11:08 PM
12 Bolt axle tubes ? JayT Transmission - Rearend 3 03-14-2004 05:22 PM
welding axles tubes 85406 Transmission - Rearend 5 12-12-2003 11:14 AM
