welding on car what do I disconnect - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2008, 09:31 AM
I have never welded anything on the car. I must disconnect my unilite do I need to disconnect battery? I have a master disconnect.
Old 03-24-2008, 09:45 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I have heard a lot of folks say to disconnect the battery but I have been welding on vehicles for years and years and have never disconnected anything....never had a problem.
Old 03-24-2008, 10:25 AM
powerrodsmike's Avatar
Wiki Edits: 161
If you are concerned, disconnect the battery, then put your ground clamp close to where you are welding, prefferably on the same structure or body part that is being welded, and you won't have any problems.
I rarely disconnect anything on the older cars I weld stuff on ...if a car has computers or alot of solid state items, that's when I disconnect the battery. Or I go next door to my buddies muffler shop and borrow his surge protector, it clamps across the battery terminals and protects the system from surges and I don't have to disconnect the battery and lose the stereo presets and other programming on the newer cars..(I don't do much work on newer stuff, but sometimes I do.)
Later, mikey
BE different....ACT normal.
Old 03-24-2008, 10:31 AM
The biggest thing is to make SURE you are connected (grounded) to the part you are working on! For example if your ground is connected to the body somewhere and you are welding on the frame you could very well do serious damage to several things , from smoking various components to actually melting the wiring. I once saw a guy welding on the bed on a Dodge pick-up with the ground lead connected to the front of the frame and it burned off the ground straps connected to the engine! I did not see this but it comes from a reliable source- another guy was welding on a Chevy truck rear end (axle housing) with the ground connected somewhere on the front of the truck, not sure where, but the u-joints got hot enough to melt the grease out of them! The bottom line is automotive ground straps are designed to carry enough current to operate lights and not welding current so making sure of what you are connected to is more important than disconnecting things. There is the argument that if a component is disconnected it has to be safe and that would certainly be true however it is not practical to disconnect everything when welding on a vehicle and disconnecting the battery will not be much insurance.
Old 03-24-2008, 11:18 AM
Irelands child's Avatar
Just reading thru my MSD 6A/AL module installation book - and they recommend disconnecting BOTH the red and black power cables to the unit as well as the tach ground wire. My interpretation of that is - if it has electronics, disconnect the battery just to be on the safe side. Why not - it only takes a couple of minutes vs the cost of a new computer of ignition box (also wasted time). If it has points, not much to hurt.
Dave W
Irelands child
Old 03-24-2008, 12:31 PM
Originally Posted by Irelands child
- if it has electronics, disconnect the battery just to be on the safe side. Dave W
Disconnecting the battery is not going to hurt anything, and is probably a good idea, but my point is don't count on that alone as insurance that all will be OK when welding on a vehicle. The disconnected battery may not help much if welding to a part that is poorly grounded to another part that the ground cable is attached to.
Old 03-24-2008, 12:48 PM
I guess I just "understand" that my ground is going to be close to where I'm welding - just one of those things my welding instructors beat into our heads many years ago at GE. We were doing stick practice with 3/8" dia. E7016 which equals big amps and on some heavy plate
Irelands child
Old 03-24-2008, 04:00 PM
I saw a guy once welding a brake line lug on a rear axle housing and he had the ground clamp attached to the wheel studs, don't know if it did any harm but the current had to flow though bearings, the axle, ring/pinion, etc and could have very well arced over at any point of contact causing a lot of damage. This was in addition to the more minor but real possibility of ruining the threads on the studs but I guess some people don't think about what could happen until it does. The thing is there is as much arc potential at the point of ground, and every place in between, as there is at the tip of the rod.
Old 03-30-2008, 08:52 PM
Just ran across this and thought it might be interesting.
www.autobodytoolmart.com/p-14355-17840.aspx
donk or lambo's got nothing on this 406chevycaprice Hotrodders' Lounge 28 01-28-2008 08:09 AM
a true story abount my first car chopperdave70 Hotrodders' Lounge 7 01-26-2008 06:13 PM
It's all in the details... Nightfire Hotrodders' Lounge 18 09-16-2006 09:53 PM
Parasol Metal body filler. x711 Body - Exterior 16 02-14-2006 09:47 AM
Buyer Beware................... poncho62 Hotrodders' Lounge 10 05-19-2005 09:40 PM
