Welding Chrome Moly Driveshaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2010, 01:06 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
What welding technique is used to weld the end yokes onto a chrome moly driveshaft tube? I have 1350 series Spicer end yokes that I need to weld onto a chrome moly driveshaft tube. I am a good welder but do not have any experience with chrome moly.
Thanks
Old 04-30-2010, 03:18 PM
big gear head's Avatar
High Performance Rear Ends
I have always used TIG to weld 4130, and I have never seen anybody else do it any other way.
Old 04-30-2010, 09:27 PM
ericnova72's Avatar
More for Less Racer
Yes, it has to be TIG(also known as HeliArc) welding, MIG or Stick is simple unacceptable and will break when using CM tubing..
Old 04-30-2010, 09:33 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
For the small price a drive shaft place charges, I'd
go there, as they balance it as well.
Rich
Old 04-30-2010, 09:52 PM
merlinsoars's Avatar
Sin Vertis Stratio
Actually any method of welding will work, some are just easier to control than others.. As far as the FAA is concerned oxy acetylene is the preferred method. The issues with welding chrome moly revolves not the method but how the heat effected zone "re crystallizes" when it cools. If care is taken to preheat before and stress relieve after, any welding technique is used will be fine. That said, my pref is gas, then tig but im an old airplane guy.
All in all do yourself a favor and take it to the driveline shop, you'll be money ahead. Ive been at this stuff along time and i still send out my drivelines
Old 04-30-2010, 10:09 PM
prostreet6t9's Avatar
Differential/Driveline
Tig it. The chances of you getting the ends in straight are pretty slim. If the ends are not in straight any D/L shop will need to cut the ends out and redue your work to get the shaft to balance out.
You might be ahead to take all your stuff to a D/L shop and have them do it for you.
Old 10-13-2010, 09:06 PM
CosmikDebris's Avatar
Last journal entry: 1974 S&W
Tig with s-2 wire, i'd start at 90amps and adjust from there. 1/16 tungsten and filler
PLEASE buy a welding respirator! MARTINSR Body - Exterior 29 11-05-2009 09:07 AM
Yesterday morning I couldn't spell aluminum welding certified, now I R one! MARTINSR Body - Exterior 9 04-01-2009 11:42 PM
chrome moly roll cage uncle dave General Rodding Tech 3 09-05-2007 01:49 PM
removing/painting over chrome that is pot metal? 72helpneeded Body - Exterior 7 05-27-2006 10:09 PM
Parasol Metal body filler. x711 Body - Exterior 16 02-14-2006 10:47 AM
