Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Welding Compressor Tank Question
Old 01-21-2010, 10:31 AM
C-10's Avatar
C-10 C-10 is offline
Revolution Calling
Last journal entry: Poverty caps live on.
Whew, I don't know about that one, sounds risky.
The problem is, that IF it IS rust, you're gonna blow bigger hole in it once you start to weld. (rusted from inside out)
Maybe a bigger problem *may* be an exploding tank.
Sometimes you can find gently used tanks locally from compressors that have went bad. That's what I'd try.
