welding door bottom - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2006, 04:33 AM
welding door bottom
1963 gmc surburan,on the passenger side i replaced the inner bottom.it was my first welding project.the drivers door needs both the inner bottom and the lower out side skin.i have purchased both.not sure where to start.do the outer,do the bottom,weld the two pieces together????? thanks
Old 09-18-2006, 06:50 AM
poncho62's Avatar
Wiki Edits: 5
Tack weld the inner bottom on, so it is solid and then the skin. That way, if you need to move the inner piece, you can. Finally, finish welding the whole thing.
Ontario Rodders
Welding info Kevin45 Body - Exterior 10 08-26-2011 08:09 AM
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 29 06-18-2009 06:54 AM
welder reccomendations? rally4x4racer Garage - Tools 32 10-14-2008 09:00 PM
Parasol Metal body filler. x711 Body - Exterior 16 02-14-2006 09:47 AM
Got a welding coach cboy General Rodding Tech 61 10-28-2005 09:03 AM
