-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   Welding exhaust piping (http://www.hotrodders.com/forum/welding-exhaust-piping-30801.html)
84Z 12-23-2003 05:32 PM
What's an adequate amp/volt needed for a mig welder to weld exhaust piping easily. Specifically aluminized 16 gauge and a higher gauge.
BOBCRMAN@aol.com 12-23-2003 05:52 PM
Depends on welder size(capacity) and wire size, gas or no gas.
84Z 12-23-2003 06:15 PM
nongas, .6-.8mm wire width
or non gas 115 volt, 90 amp max, 0.035'' or 0.030'' wire capacity, flux core wire
willys36@aol.com 12-23-2003 10:00 PM
I use oxy/acetylene on header construction. Give a lot more control and cleaner looking job. Also, remember to run a brazing fillet around the tube/flange joints. Improves strength, quietness and extends the life of the header.
302 Z28 12-29-2003 08:06 PM
Do not buy a 120v MIG machine, you will soon wish you had purchased a 230v one instead.
Vince
tm454 01-02-2004 02:39 PM
Lincoin makes and excellent 120V welder. I got a welder with the gas option and cart used for $325. Watch the papers for a used one or get a new one and build your cart.
Tazz
Rat Rods Rule!
