Welding exhaust piping - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2003, 05:32 PM
84Z 84Z is offline
Gas Raper
What's an adequate amp/volt needed for a mig welder to weld exhaust piping easily. Specifically aluminized 16 gauge and a higher gauge.
Old 12-23-2003, 05:52 PM
BOBCRMAN@aol.com's Avatar
Depends on welder size(capacity) and wire size, gas or no gas.
Old 12-23-2003, 06:15 PM
84Z 84Z is offline
Gas Raper
nongas, .6-.8mm wire width
or non gas 115 volt, 90 amp max, 0.035'' or 0.030'' wire capacity, flux core wire
Old 12-23-2003, 10:00 PM
willys36@aol.com's Avatar
Wiki Edits: 21
I use oxy/acetylene on header construction. Give a lot more control and cleaner looking job. Also, remember to run a brazing fillet around the tube/flange joints. Improves strength, quietness and extends the life of the header.
Old 12-29-2003, 08:06 PM
302 Z28's Avatar
Do not buy a 120v MIG machine, you will soon wish you had purchased a 230v one instead.
Vince
Old 01-02-2004, 02:39 PM
Tazz
Lincoin makes and excellent 120V welder. I got a welder with the gas option and cart used for $325. Watch the papers for a used one or get a new one and build your cart.
Tazz
Rat Rods Rule!
