You must either remove the source of the gas fumes, or neutralize them so that they are not a concerne. If you remove the tank seal all lines so they they will not leak. The tar like substance under the trunk floor needs to be removed also before any welding takes place.
Vince |
Welding a floor above a gas tank
Hi evltwin. If the gas leak was aprox 3 years ago and was fixed at that time, there should be no reason that the gas would give you a welding hazard. I would remove the gas tank and plug the gas lines, dry off the lines and vent the area (if inside a garage or building) If still concerned about a fire I have used wet rags and laid over the parts in question. Remember that gas vapor/fumes will ignite faster the raw gas in liquid form. BE SAFE, DON'T DO IT IF YOU DON'T FEEL SAFE.
Look on the bright side - you may come up with a good story for this thread!
