-   -   Is welding frame of 1937 Buick OK? (http://www.hotrodders.com/forum/welding-frame-1937-buick-ok-218624.html)
Mutt's37Buick 04-25-2012 05:46 PM
A neighbor of mine who builds hot rods said that certain years of Chevys have a frame that is all riveted construction. He says that the frame is designed to flex and added welds will crack.
The welds that the car builder will be adding to my chassis will be to add mounts for suspension, engine, and transmission upgrades.
1) Does anyone if it is OK to weld such mounts on the frame of my 1937 Buick Roadmaster?
Thanks
Mutt
S10 Racer 04-25-2012 07:08 PM
Thanks
Mutt
All steel construction is designed to flex. If it didn't, it work crack and break. Just so you know for future reference a rule for welding frames is to avoid a vertical weld on the frame sides. The items you are talking about welding on should be fine.
jetnow1 04-26-2012 01:54 PM
Buick frames are much different than chevy top hat designs. Your friend is
right about chevy's but your frame is much stronger, you should be fine.
Mutt's37Buick 04-26-2012 02:22 PM
Thanks for the info.
Mutt
