Is welding frame of 1937 Buick OK? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2012, 04:46 PM
Mutt's37Buick's Avatar
A neighbor of mine who builds hot rods said that certain years of Chevys have a frame that is all riveted construction. He says that the frame is designed to flex and added welds will crack.
The welds that the car builder will be adding to my chassis will be to add mounts for suspension, engine, and transmission upgrades.
1) Does anyone if it is OK to weld such mounts on the frame of my 1937 Buick Roadmaster?
Thanks
Mutt
Old 04-25-2012, 06:08 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Thanks
Mutt
All steel construction is designed to flex. If it didn't, it work crack and break. Just so you know for future reference a rule for welding frames is to avoid a vertical weld on the frame sides. The items you are talking about welding on should be fine.
Old 04-26-2012, 12:54 PM
Buick frames are much different than chevy top hat designs. Your friend is
right about chevy's but your frame is much stronger, you should be fine.
Old 04-26-2012, 01:22 PM
Thanks for the info.
Mutt
455 in 1937 Buick Mutt's37Buick Engine 3 05-13-2011 03:35 PM
1958 buick onto 1993 buick frame/floor flatlandlowrider General Rodding Tech 5 03-27-2011 07:17 PM
1937 Buick suspension upgrade Mutt's37Buick Suspension - Brakes - Steering 6 03-18-2011 08:56 AM
1937 Buick lowered Obmlr Suspension - Brakes - Steering 6 11-26-2009 10:14 AM
1937 Buick front Spindle Interchageability SteveHotRod Suspension - Brakes - Steering 4 01-16-2008 10:05 AM
