welding gas cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2006, 02:54 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
I converted my lil flux core welder to mig and the only thing I need is a gas cylinder. Where can I get one and whats a good price? I don't need anything to big..Oh.. also what is the best shielding gas to use?
Old 04-15-2006, 03:21 PM
Wiki Edits: 31
Argon gas. buy the cylinder where you go for the gas, they have them
Old 04-15-2006, 05:27 PM
weirdbeard's Avatar
1976 Ranchero GT
Why argon? Why not helium or c02.. I am curious.
Old 04-15-2006, 05:37 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Use the Argon /C02 mix its cheaper and does a good job. You do not need straight Argon unless your going to be welding aluminum. Buy the bottle where you buy your gas.
Old 04-15-2006, 05:52 PM
weirdbeard's Avatar
1976 Ranchero GT
How much would a lil bottle cost roughly? I am broke as a bone!.. Tax time! Got to rebuild Iraq! Dick Cheinys tax return is 1.9million! Mine is minus 5 grand! Sorry..... I have seen some kind of gas cylinders a harbor freight....
Old 04-15-2006, 05:55 PM
Bittles55's Avatar
WELL I LOOKED IT UP AND IT SAYS THAT ARGON MAKES A FREE OXIDATION WELD AND THAT CO2 IS AN IMPURITY WHICH WOULD MAKE IT WEAKER I GOT THE WEBSITE IT IS http://www.jmgpt.com/html/high_purity_weld_argon.html AND WHEN I ALWAYS HAD A TANK WE JUST LEASED THE TANK AND IT WAS LIKE 60 BUCKS TO REFILL IT
Old 04-15-2006, 05:58 PM
Bittles55's Avatar
What Price Range Are You Looking For
Old 04-15-2006, 06:01 PM
weirdbeard's Avatar
1976 Ranchero GT
Thats Cool. I guess thats why you want pure argon for welding aluminum. I don't think I weld enough to justify leasing a tank. I think I would save in the long run just buying one. Thanks!
Old 04-15-2006, 06:02 PM
weirdbeard's Avatar
1976 Ranchero GT
THe cheaper the better!
Old 04-15-2006, 06:03 PM
Bittles55's Avatar
A 20cf Bottle On Ebay Would Cost About 65 Dollars
A 40cf Bottle On Ebay Would Cost About 95 Dollars
A 80cf Bottle On Ebay Would Cost About 140 Dollars
Hope I Cold Be A Help I Know How You Feel About Taxes And I Work For The Government
Old 04-15-2006, 06:05 PM
weirdbeard's Avatar
1976 Ranchero GT
Of course! Ebay! Thanks
Old 04-15-2006, 06:14 PM
Bittles55's Avatar
Not A Problem Anytime You Need Help Just Ask I Will Do My Best
Old 04-15-2006, 07:42 PM
Lost in the 60's
Wiki Edits: 4
You might have trouble getting your bottle filled if you do not buy it from the welding supply where you intend to buy your gas. They do not like to fill bottles that they are not sure of and could charge you for testing and certification of the bottle. Call your local welding supply and they can give you the price. I bought my bottle from my welding supply and when its empty I exchange it for another one and pay for the contents that way I do not have to leave it to be filled and have to go back to pick it up. For welding steel all you need is 75% Argon/25% C02 mix.
Old 04-15-2006, 08:18 PM
If there is a Tractor supply nearby most of the stores have welding gas. CO/2 is cheaper than C/25 but The C/25 (Argon/ CO/2 mix) makes a much better weld. Pure Argon is not even an option as it will not work very well at all on steel.
Old 04-15-2006, 09:41 PM
weirdbeard's Avatar
1976 Ranchero GT
I bet I could find a tractor supply. Oldred I was hoping you might give your two cents! So for the best mig weld on steel you want an argon c02 mix. I am looking forward to cleaner nicer welds with this mig conversion!
new welding wire oldred Body - Exterior 93 05-07-2009 04:40 PM
Welding Aluminum Cylinder Head Chevy21 Engine 13 05-08-2005 09:17 PM
1969 Camaro gas pedal harry48 Interior 1 04-21-2005 08:17 AM
what cylinder pressure??? Lthompson Engine 5 02-12-2005 01:04 PM
Who Said No Such Thing As Bad Gas 1BAD80 Hotrodders' Lounge 4 11-20-2004 08:04 PM
