welding on gas tanks - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2011, 06:55 PM
I was reading all the members experiences while welding on fuel tanks and I respect everyones experiences and I am sory about the fatalities and accidents mentioned. However my experience concerning the subject is very simple. I grew up in Puerto Rico and we were very poor. As the Island is sourounded by an ocean, salt is every where around you. Gas tanks ussually rust easy. So been poor we do not have a choice but to weld and patch our tanks. The way I weld without any fear!! is removing the sending unit and making sure the fill tube is open, fill it all the way to the top with water, aply an open flame through the sending unit hole. A very small noise indicates the little fumes left between the water and thevery top of the fuel tank just burned up. No danger at all and most of the times you do not even notice the noise.
At this time you can drain the water and weld all you want or cut it in pieces if you want to dispose it.
Like I said, this is my way of welding on tanks. I have been doing it for 45 years in the auto restoration bussiness without a single incident.
Old 02-10-2011, 07:01 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
I have done and have seen done many things that I won't confess to , in the interest of saving a buck. LOL . Would never recommend any of them .
Old 02-10-2011, 07:21 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i will do alot of stuff that i will NOT recomend to other people
Old 02-10-2011, 07:42 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Do I hear an echo in here ? LOL
Old 02-10-2011, 08:27 PM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
Bunch of sissies. Good thing our forefathers wheren't a bunch of scared wussies, scared to take a chance on something unknown or dangerous, otherwise we would still be roaming around in the dark scared of every little noise. This country was built on people being adaptive and doing what it took to get the job done, Now accountants and lawyers and ***** *** government agencies have neutered this country so much we can't even fix our own car without having to buy a new part cause someone says its dangerous to rebuilt or repair something, Man up and get your balls out of your wifes purse.
Old 02-10-2011, 08:39 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
I am not saying that I'm afraid to repair my own parts. I just would not necessarily tell someone else to do it that way. How about cutting a pitman arm in two and rotating it 180 degrees and welding it back together. I did it on my T-bucket but sure wouldn't do it on somebody elses car. You can if you want , but not me.
Old 02-11-2011, 01:56 AM
4 Jaw Chuck's Avatar
My experience with any kind of fuel tank is that welding it is a temporary solution to a permanent problem, I've always used epoxy for temporary repairs with excellent results...even full of fuel. Had one epoxy repair last three years because I tried to unfold a bent flange which cracked while I was bending it...while full of fuel!
With replacement tanks available for any kind of vehicle for $150 or less you have to wonder how much your really saving welding a rusted tank thats only going to leak again in the near future as opposed to replacing with new...Puerto Rican availability notwithstanding.
How much did you charge for removing a fuel tank and filling it with water to weld it and then replacing it again...bet it would have only cost another few dollars to put in a new tank (and straps!). An temporary epoxy repair and then subsequent replacement would have been safer and a better investment.
Just sayin...
— Han Solo
Old 02-11-2011, 06:49 AM
World Famous VF-14
Just sayin...
Lotta cars you can't get tanks for still.
Old 02-11-2011, 08:08 AM
Really? Where do I buy one for my 1962 Olds F-85 wagon?
Oh, I didn't think so...
Old 02-11-2011, 08:37 AM
Sky diving is safe but one screw up is 99.9% fatal only because it was not some ones day to die. Russian roulette is of the same mold, but one out of 6 odds are not good enough for me. I have been injured enough in my life time and will NEVER, NEVER, NEVER weld on a gas tank or any other container that has had a volatile substance in it. I am so paranoid about these time bombs that I will only use a flash light to look inside and is never activated near the opening.
Trees
Old 02-11-2011, 10:17 AM
Trees
You certainly shouldn't do something that you don't feel comfortable doing, but in reality there are very safe procedures for welding gas tanks. It is mandatory that the interior be cleaned of volatiles, preferably by using an appropriate emulsion solution to neutralize the vapors. Once that's done and the tank is washed out, it's safe. The problem I had on my 62 was that the design of the internal baffles prevented me from completely emptying the solution out of the tank. That's a P.I.T.A.
Old 02-11-2011, 10:29 AM
sqzbox's Avatar
My pipes are my music
Learning from others mistakes is why some of us still have our gonads in our pants and not smoldering on the ground.
Old 02-11-2011, 10:40 AM
This is not a joking matter but unfortunately a lot of people feel that way and those are the people we hear about sometimes. I was in the welding and equipment business for many years and I saw a lot of serious accidents, almost every one of them was caused by someone taking a risk they were aware of before hand. As far as welding on fuel tanks I have personally seen the results of this twice and heard about several more in official mine safety bulletins so they were not just hearsay. One fuel tank fatality resulted from a guy using the VERY STUPID practice of purging the tank with exhaust gas, this STUPID trick has hurt a lot of people. The other one was an old Jeep gas tank that exploded and burned a guy that had been a full time mechanic for many years and although he survived he is crippled and badly scared, talked to him a while back and believe me this fellow is hard to look at. Take chances if you like but sooner or later the luck will turn to the wrong kind and another statistic will be added. The guy hurt with the Jeep gas tank just kept saying "I can't believe I did that I know better" but of course by then it was too late. Fellows if you won't recommend doing something to someone else then DON'T DO IT YOURSELF!
Old 02-11-2011, 11:31 AM
Originally Posted by oldred
...Fellows if you won't recommend doing something to someone else then DON'T DO IT YOURSELF!
Excellent advice. Unfortunately, sometimes it's just evolution in action.
Old 02-11-2011, 01:03 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
If I ever wanted any dynamite shrink wrapped, could I bring it over to your shop, you must have a propane torch laying around.
Welding Used Gas Tanks Quinte Hotrodding Basics 11 04-21-2009 09:02 AM
Butt welding vs Spot welding 69ChevelleAddict Body - Exterior 19 05-04-2008 02:47 AM
old gas tanks knighthawk Hotrodding Basics 8 04-26-2007 08:45 AM
Gas tanks chrisflock Hotrodding Basics 5 11-02-2006 02:08 PM
gas tanks 38 special General Rodding Tech 14 09-30-2003 06:52 PM
