Welding helmet?
Hi guys I was spot welding on the scout today and was turning my head and closing my eyes instead of wearing a mask so I could go quicker but now my face is burned and my neck is soar so its time to buy a automatic welding helmet. I am talking about the ones that go dark on there own as soon as you start to weld.
-I am only a hobbyist so I don't want to spend a fortune but the lens has to dark quickly or my eyes will be the next thing to go. So were can one get a good deal on one? I don't want a piece of junk or the top of the line either. What should I look for? I thought about a harbor freight one but I don't want a piece of junk...... Ideas thanks......... |
You will be lucky, If that's all you burnt.. And not your eyes.. The shield's from harbor freight, do work very good. I'm on my second one in five years. I use mine ''everyday''.. |
We have covered this many times in the past and it is a fact that an auto dark helmet offers protection even in the lightened stage so you will not burn your eyes during the time it takes to go from light to dark, that is simply a comfort issue not a safety concern. "Urban legend" type sob stories abound about some poor worker who was forced to use a malfunctioning helmet that darkened too slow or had a job just tacking parts that required the helmet to darken hundreds or thousands of times a day which burned his eyes because of the multiple flashes. These stories are simply not true and the time it takes a helmet to go dark will not expose the user to harmful amounts of UV/IR in spite of what some will say.
BTW, those HF helmets are darn good ones! The headgear and the shell are not the best and for that reason I would recommend a better helmet for a pro welder working with it everyday but the electrics are up to the job and many pros do use these things. For a hobbyist or the home shop they work great and for the cost are hard to beat! |
I have tried a number of autodarkening helmets, I just don't like them. I don't like the lack of control in how they "fade" in and out.
I have been using a Cherokee for well over 10 years now and have one both home and work. You have complete control and it even doubles as a grinding helmet by flipping the lense all the way up. They are about $90 bucks I believe off the website. http://www.accustrike.com/ Brian |
I have been meaning to get one of those things for a while now but I just never get around to it (round tuits are hard to get you know,
). I don't care for the auto dark for MIG welding which is the very thing most people do like them for but, to me, the darn things just darken the view of the arc too much right at the weld puddle making a small seam very hard to see. This effect has nothing to do with the shade setting since the way the things work makes them darkest at the brightest point. I am not alone in this gripe as a couple of other guys here have complained of it too, one even started a thread about it a couple of years ago unless I am mistaken. My point is if MIG welding body panels is to be the major use then try both types of helmet and see if the better view of the conventional fixed type is worth the trade off, that Cherokee however should have the best features of both types of helmet.
Another thing about MIG welding is you are often in a dark place inside a car or something and with the auto darkening helmet you need a lot of light on the weld area to see being it STARTS out as something like a number 4 shade. Where as the Cherokee starts out perfectly clear.
I have preached and preached these helmets since the day I bought mine. I think they are the cats meow and MUCH better than an autodarkening for the bodyshop/garage. And again, I am always looking for a BETTER way to do things and have given some real nice autodarkening helmets a good try, not just one weld but using them for a day to get the hang of it. I just can't get into them, don't like them at all. Brian |
No problem's with mine..
I'm presently attending a (continuing education) welding class at the local agricultural college.
They supply the "old-school" welding helmet with a #12 shade and the little "flip-up" window. I couldn't see a darn thing ... striking arcs in the middle of the plate ... or even on the goldarn table! LOL I noticed that a couple of students had brought there own auto-dark helmets, and that the instructor had his very own $400.00 Miller ... complete with the "flame-job" So, OK ... I went shopping around for a less expensive version. Canadian Tire (also known as "Crappy Tire") had a Lincoln Helmet / Welding Glove combo for $199 CAD. I probably would have bought that one except that I already had the gloves. Peavey Mart had a couple of Hobart "The Hood" (XVS) models available. One with the flame job for $209, and a plain black one for $169. I bought the black one. (#770424) Hobart XVS The shade is adjustable from 9-12, and it has another knob to adjust sensitivity. It apparently has a #4 shade setting in the brightened state. I like it. It's a heckuva lot better (and lighter) than the "old-school" helmet, that's for sure. Plenty good enough for a hobbyist like me. Tuesday was my first experience with MIG welding, and I'll be going again tonight. It sure was nice to be able to position that stinger right where you wanted it to be, and just pull the trigger. |
If you haven't tried it, don't knock it. You may be surprised to find it is much better for you. But as we all know, one guys favorite tool is another guys waste of money. I have welded hours on end without a problem. One thing is you don't need to open your mouth nearly as much as the little graphic does. Keeping your lips closed, just separating your teeth a little is all that is needed. It is SOOO different that it takes a little time getting used to. But I wouldn't do without mine for anything! Brian |
I would assume you can't wear a respirator with that particular helmet Brian.
Rob http://www.1969supersport.com |
I have the one from HF and it gets the job done.
miller
If you dont wont to spend money the harbor freight would be ok. I have used jackson hobart and miller. I love my miller pro about $200 it has a #3 and then changes to a #10 but Can go up. The jackson I think had a #4 and that is dark I bet the harbor one has a #4. THe hobart I used also had a #3 and was nice. But I think the same as the miller. For my money I would and have gone with the miller.
Q about light/dark changing time.
I'm a little confused about how the different helmet brands describe the switching time on their auto dark helmets.
For example: Miller Pro Hobby is changing from light to dark in 1/12000 sec, while their more expensive Pro Elite use 1/25000 sec. That makes sense, but when I look at Lincoln helmets, their entry level Viking Tribal uses 1/25000 sec, while their more expensive Vista 3000 uses 1/10000 sec??? I would say 1/10000 is a slower change than 1/25000, right? But in that case, the 200$ Lincoln Vista changes from light to dark slower than the 120$ Lincoln Viking... |
It sure can, I wouldn't weld without one. I use a 3M disposable. You can't use a dual cartridge type, no. But you can use a single cartridge or a disposable as I do. Brian |
| Recent Garage - Tools posts with photos |
| Welding info | Kevin45 | Body - Exterior | 10 | 08-26-2011 08:09 AM |
| "Basic of Basics" Welding - How do I repair body panels? | Centerline | Body - Exterior | 29 | 06-18-2009 06:54 AM |
| welder reccomendations? | rally4x4racer | Garage - Tools | 32 | 10-14-2008 09:00 PM |
| Product review and warning: $99 craftsman (sellstrom safegaurds) welding helmet | lowROLLERchevy | Garage - Tools | 15 | 06-25-2006 04:11 PM |
| Parasol Metal body filler. | x711 | Body - Exterior | 16 | 02-14-2006 09:47 AM |
