Welding helmet - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2004, 03:06 PM
Welding helmet
I am taking a welding coarse at the local vocational school at night starting in a week.
The brouchure says that everyone must supply their own welding helmet, gloves and safty glasses.
I looked at a few sights and saw that helmets come in all different shades numbers 9, 10 11,... and also auto darkening.
I'm not doing this for a living so I don't want to spend a million dollars but I don't want to wish I got something better after I bought something.
Any suggestions on what to buy and from who.
Thanks, Mark
Old 09-18-2004, 03:31 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
any welding place will have what you want. i use a #10 lense on my helmet. you can change out the lenses if you want so maybe you should pick up an inexpensive helmet and buy an extra lense.
as for the auto-darkening they are nice but the cheapest one i've seen is around $150. i've never used one so i don't know what they're like to work with, although i've wished i had one from time to time.
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 09-18-2004, 05:35 PM
welding helmet
I would definately recommend an auto darkening hood. They are a bit pricey, a good one will set you back about $300. They are worth it, though, especially if you are planning to weld professionally or just often. I would recommend one that has settings for shades 9-12 and four sensors. If you are TIG welding it helps to have the extra sensors as the positioning of your hand feeding the filler rod can sometimes block a sensor. Also the auto darkening hoods are good for beginners because you can see where you need to start your weld and won't miss when you strike an arc.
Old 09-18-2004, 06:59 PM
Ratdoggy's Avatar
Hammer torch chisel...
Last journal entry: Getting there
Eastwoodsgot one for $90 auto darkening. I have an automatic and I like it . Everytime I set up a weld with the old style and then nodded my head to drop it down I lost my positioning.
Old 09-19-2004, 09:37 AM
302 Z28's Avatar
I know I will be blasted for this, but I love my HF auto darkening hood. It is on sale now for $49. My next door neighbors son is a certified welder and he bought one for home use. He says it is as good as his expensive one that he has at work.
Vince
Old 09-20-2004, 02:17 AM
Old enough to know better
After spending many years welding with a conventional hood and breaking suspensions and flip up lenses, the first advice I'd give to a new welder is to get an auto-dark helmet. Life will be much easier. Go with a cheapie until you find out what you like or actually need. I found one off eBay. It requires some batteries and you have to turn it on and off with a switch inside but it goes all the way down to shade 7 which is nice for low current mig on sheet metal.
Old 09-20-2004, 09:40 PM
HF has a cheap one on sale this week
http://www.harborfreight.com/cpi/cta...emnumber=46092
Old 09-21-2004, 12:25 AM
POOR SEND HELP!!!
I may give one of those a try. I had the cash saved up for a Miller or Speedglass untill I had to replace a windsheild
Old 09-22-2004, 10:05 AM
bigbird's Avatar
Last journal entry: Blasting Cabinet
I got my auto-darkening helmet off of E-bay and love it.
Old 09-23-2004, 07:07 AM
Dejavu's Avatar
Not so New Member
Last journal entry: Trying to make a custom valance
Just received my HF autodark last night 49.95, shipped free because I ordered over $50. It is great! I can concentrate on where my wire is and not have to move my hand to flip my helmet.
Good Luck,
Fred
Old 09-24-2004, 04:51 AM
Thanks for the info. I just ordered the helmet and some welding gloves.
Old 09-24-2004, 08:33 AM
Slickriffs's Avatar
I just bought my first Helmet..The auto darkening one for $49.00 at HF..I love it! Now I have another free hand.
Old 10-03-2004, 07:45 PM
daimon1054's Avatar
The lense depends on the welder, tig and mig I find I need a pretty light lense for stick I like a dark lense. Back lighting also changes how well you see through the lense.
Old 12-09-2004, 09:38 AM
OFN OFN is offline
For those of you doing TIG, you might want to take a look at some of the TIG specific auto dark lenses. They work better with the high freq starts of a TIG and don't *shock* your eye's quite as bad.
I'm pretty fond of the Arc 1 hoods right now. IMO, they beat out the Jackson, MIller, and Optrel hoods, and the HF hood by a MILE!!
KP
Old 12-10-2004, 08:03 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Tigging aluminum needs a higher lens rating as well. 14 was what my instructor told me. I bought a variable Miller helmet. Love it !
