Welding helmet shade lense problem??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2006, 06:51 PM
workingclass's Avatar
Tool & Die Repair God!!!
Hey guys, I have a jackson welding helmet with auto darkening and my filter stopped working. I stuck it in front of a shop light for a few hours thinking since it was a solar it would recharge itself like a calculator but all it will do is blink and pulse really fast. My question was is there any way to recharge these or is it just its time to go? Its a shade 10 filter pearson with the date of 1/28/03 on the bottom. Is there any type of shelf life for these and how do they work?
Thanks for looking,
Kevin
Old 07-30-2006, 07:21 PM
Depending on which model it is the batteries in the Jacksons are replaceable, unlike most auto dark hoods. That sounds like it could be a battery problem but most of the time if you leave one with bad batteries in a bright light for a while, sunlight is best, it will usually work ok for a short time. You could contact Jackson they are pretty good about standing behind their products and they may be able to help you out.
Are the sensors blocked by a smudged cover plate? or possibly the sensors are smudged under the cover plate?
Old 07-30-2006, 08:37 PM
re: Welding helmet shade lense problem???
Thanks for the reply oldred. I cleaned everything off of it and let it sit most of the day under false lighting and a few hours under the sun, not it will blink on and off really fast but nothing consistent. I guess I will try leaving it out while i'm at work tomorrow and see what happens. We use the same helmets at work and have never had a problem but i'm guessing since my garage is so dark being that i'm only in it a few hours throughout the week and not even to weld that it has no time to recharge or maintain a charge. I will try going on the jackson web site to see if there is any kind of warrenty or maybe just incuire about a battery. Are the batteries inside of the black plastic lense?
Kevin
Old 07-30-2006, 08:55 PM
Ok, i see on the jackson web site that all solar powered shades are pretty much disposable after they stop working. thanks for all the help.
Engine stalling problem JamesRS Engine 3 01-30-2006 11:22 AM
1994 Saturn Transmision Problem dmg53 Transmission - Rearend 4 01-18-2006 06:59 PM
Welding Books Magnus_Jager General Rodding Tech 6 11-29-2005 03:57 PM
please help..... annoying warm start problem 67cuda Engine 21 03-28-2003 05:44 AM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 05:18 PM
