Welding Help - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-31-2013, 08:04 PM
wire sticks in tip
I am in the beginning stages of learning my mig welder, a Miller Autoset 180. I am getting to the point I can occasionally make a decent weld, and join two pieces of metal together.
My problem, a lot of times when I try to start a weld, it just "pops" briefly when it strikes an arc, and the wire sticks in the feed tip. If I turn the clamp on the feed roller up, the more likely is it I get a "bird nest" starting.
The problem is more pronounced with .024 wire, than .030 wire.
  #17 (permalink)
Old 01-31-2013, 08:27 PM
You likely have a worn out tip or the wrong size. Your tip size needs to match your wire diameter. Have you checked that? Also, cutting the wire off before you strike the arc the better off you will be to, the wire "pokes" the metal making a clean start.
But I would say it's likely your tips wrong or worn out.
  #18 (permalink)
Old 01-31-2013, 09:28 PM
life is a temporary assignment
Sounds more like your wire feed speed is to slow..
  #19 (permalink)
Old 02-01-2013, 11:05 PM
put up or shut up
I agree. probably has a stuttering sound to, right? When you turn the wire speed up up you'll hear the frying bacon sound you want to achieve, but remember, you can achieve that sound every time you turn up your amps as long as you turn up your wire speed too, so it doesn't necessarily mean you are where you want to be, just means it's a good setting for some metal thickness, but maybe not yours. The key is to find the highest you can go with that sound
where it won't burn thru with quick tacks.
To make life easier I have a couple settings I have jotted down...
open butt weld setting
bigger gap open butt weld setting
plug weld setting
3 layer plug weld setting
My plug weld setting is my settings I use to also weld a seam where it's flanged under it or welding the edge of a lapped panel. My bigger gap open butt weld settings is also the settings I use to tack close pinholes where it doesn't call for a patch, if it burns away then I determine the metal is weak and need a patch. My 3 layer plug weld settings is also my settings for welding 16 gauge lapped for brackets and what not, or a plug weld with 16 gauge.
All these settings are simply a starting point. A lot depends on how straight the line is. If it's not so straight I'll probably have to turn up the wire speed a tad, but I don't sit there and test metal. I already know the welder. I'll sacrifice a tack or two and adjust by sound and what the wire is telling me. If the wire is doing what's happening to yours I need more wire speed. If it's pushing the work away and leaving big wire ends it's too fast. My goal is the flattest puddle I can make with the right sound. This means I must do fast tacks or it will burn thru. Sometimes a slightly slow wire speed will get you the best welds but are inconsistent. The sizzle will give good welds no matter how you move the line around while moving to different welding spots. some welders are also quarky. Some don't work the same every time, mainly old ones. Having a new miller will leave you awesome welds every time.
  #20 (permalink)
Old 02-02-2013, 12:31 AM
MAN !!!!
Welding is so much more easier then posted in this thread...
  #21 (permalink)
Old 02-02-2013, 08:19 AM
put up or shut up
Originally Posted by NEW INTERIORS View Post
MAN !!!!
not sure if I confused him more than I helped. Well at least I wasn't posting up frequency waves and crap like that.
  #22 (permalink)
Old 02-02-2013, 04:51 PM
No !!! It's just sometimes people post things here that will make some people think they can't do it... I didn't take any school at all,,(self tought)..I got certified in many different type's of welding... A lot of what I was certified in was X-Ray weld's.. If you have the WANT to learn,, You WILL learn..Yes some schooling will help jump start you... But you can move forward witout it..
  #23 (permalink)
Old 03-16-2015, 09:10 PM
Best advice.. Learn to weld the material you want weld with scrap pieces.. Use the guide inside the welder for initial settings and just do it. Experience it and learn from it.. Books and videos only do so much.. Its all hand eye cordination .. The rest will come with time.. Dont be afraid to adjust settings high pto low and same with wirespeed that way you know what the welder is doing ..be patient and have fun with it.
how to weld, tig welding, welding, welding help
"TIG" welding gloves vs MIG welding gloves. MARTINSR Garage - Tools 15 04-09-2011 08:39 AM
Butt welding vs Spot welding 69ChevelleAddict Body - Exterior 19 05-04-2008 01:47 AM
welding brian berwick Hotrodding Basics 2 05-24-2007 05:01 AM
Welding's not going well... gt2betubbed Hotrodders' Lounge 13 08-26-2003 06:10 PM
Welding xxx(madmax )xxx General Rodding Tech 4 03-01-2003 08:10 PM
