Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Welding Help...... Floor Pan Replacement ? Experts Welcome !
Old 08-27-2010, 05:28 AM
mustangsal's Avatar
mustangsal mustangsal is offline
Check the pics. On the front you want to be on the lower arm toward the wheel. It may even have the stock jack point there. In the rear you want to put them under the shock plate (where the rear is bolted to the springs and the shocks attach).
Pics are from a Mustang, but yours should be similar.
ID:	47725   Click image for larger version
