Welding info - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2003, 03:39 PM
Kevin45's Avatar
Just one of the guys
Welding info
Ran across this. It's put out by Miller Welding. Some good info for those who may want it.
MAKING A SOUND MIG WELD
The ability to make a good MIG weld is extremely important to the success of an auto repair technician. In fact, almost every welding repair made on a unibody car, light truck or van can be made with the Metal Inert Gas (MIG) welding process. For this reason, there are well-accepted standards and practices for producing sound MIG welds.
Note: This article is written for the person with a basic familiarity with welding who wants to practice and improve their welding technique. The process of arc welding poses several potential hazards that must be guarded. Therefore, all information relating to the safe operation of welding equipment and welding processes must be fully understood before attempting to begin work. Always read and follow the safety information in the operator's manual or contact the manufacturing company when in doubt.
What Needs Welding?
The front driver's side corner of a vehicle receives more damage than any other area. Parts damaged in this area include the upper rail, frame rail, radiator core support, and fender aprons. Other parts often damaged include the rear body panels, trunk floor, and lower rear rails. To make these repairs, the technician must thoroughly master all-position welding. It is important to practice so that you feel confident with making sound welds in all positions.
One way to become confident in your welding quality is to use a simple welding machine, such as the Millermatic® 185 from Miller Electric Mfg. Co. It comes complete with a package to get you started, including a 6 ft. power cord with plug, 10 ft. MIG gun and cable assembly, and 10 ft. work cable with heavy duty clamp. The package also includes a gas solenoid valve, flow gauge and 5 ft. gas hose, and factory installed running gear/cylinder rack.
Before making a repair weld, make test welds on material of the same type, thickness, and joint configuration. Visually inspect and destructively test the practice weld to ensure that it is sound before welding on the vehicle. Fine tuning the welding parameters and your technique on test welds improves the quality of the repair.
Welding In the Flat Position
For a flat joint, such as a butt joint, hold the gun at a 90 degree angle to the workpiece, directing the filler metal straight into the joint. A small, back and forth motion with the gun can help fill a large gap or when making multiple passes.
For a fillet weld on a T-joint, keep the gun at a 45 degree angle, or equal distance from each piece. When making multiple weld passes, the work angles change slightly. This helps avoid uneven weld beads and undercuts.
For a fillet weld on a lap joint, angle the gun between 60 and 70 degrees. The thicker the metal being welded, the greater the angle.
Plug welds should be made with the weld in the flat position if at all possible. Using a spiral-type technique, weld in a slow motion around the edges of the hole, making a complete circle before working toward the center (starting the spiral too soon can create pinholes). When welding around the edge, angle the gun slightly, somewhat like you would for a lap joint. Keep the gun perpendicular when filling the rest of the hole.
Horizontal
Because of the effects of gravity, the gun work angle must be dropped slightly by 0 to 15 degrees when welding horizontally. Without changing the work angle, the filler metal may sag or rollover on the bottom side of the weld joint. The travel angle, whether using a push or a drag technique, generally remains the same as for a weld joint in the flat position.
On thick metal when making multi-pass welds, or to bridge a slight gap where fit-up is poor, weave beads may be used to fill a weld joint. A back-and-forth weave, with or without a slight arch, is used in the horizontal position. A slight hesitation at the top toe of the weld helps prevent undercut and ensure proper tie-in of the weld to the base metal.
Voltage and amperage settings for welding in the horizontal position are usually the same, or very slightly less, than settings for welding in the flat position. However, note that if the wire diameter is too large, the resulting heat and size of the weld puddle may be too great to allow the weld puddle to freeze quickly, and the weld may rollover.
Vertical Positions
Vertical welding, both up and down, can be difficult. This makes pre-weld set-up very important for making high quality welds. Since you are fighting gravity, consider reducing the voltage and amperage 10 to 15 percent from the settings for the same weld in the flat position.
Know when to weld vertical down and when to weld vertical up. For vertical down welding, the welder begins at the top of a joint and welds down. This technique helps when welding thin metals because the arc penetrates less due to the faster travel speed. Because vertical down welding helps avoid excessive melt-through, welders sometimes place very thin materials in the vertical position even if they can weld them in the flat position.
When welding vertical down, angle the gun slightly back into the weld puddle at a 5 to 15 degree angle. For thin metal where burn-through is a concern, angle the gun slightly up and pull it downward (i.e., direct the wire away from the weld puddle). Either way, keep the electrode wire on the leading edge of the weld puddle. A very slight weave may help flatten the weld crown.
The vertical up technique — beginning at the bottom of a joint and welding up — can provide better penetration on thicker materials (typically 1/4 in. or more). The travel angle of the gun is a 5 to 15 degree drop from the perpendicular position. A slight weaving motion can help control the size, shape and cooling effects of the weld puddle.
Making a plug weld in the vertical position is somewhat similar to making a vertical up fillet weld. For a vertical plug weld, the filler metal is deposited upward along one side of the hole. Then, another bead is deposited from the bottom to the top on the other side of the hole. Alternate sides until the hole is filled. For thin metal, use a similar technique, but weld in the vertical down position to prevent burn-through.
Overhead Position
Drag, push or perpendicular gun techniques can be used for welding overhead. But, because of gravity, travel speeds must be fast enough so that the weld metal does not fall out of the joint. Also for this reason, weave beads should not be too wide. Using smaller diameter electrodes (e.g., .023 in.) and lowering the voltage and amperage help keep the weld puddle small and more controllable, too.
Work angles and travel angles for the overhead position can be thought of as the same angles for the flat position, only upside down. However, be sure to keep the gun nozzle clean, as spatter can build up much faster when overhead welding. Also, because the shielding gas flows upward, you may have to increase the gas flow rate to ensure proper coverage.
Travel Speed and Stickout
Travel speed and electrode extension (or stickout) also influence the shape and quality of a weld bead to a significant degree. Travel speed is the rate at which you move the gun along the joint. Many experienced MIG welders can determine the correct travel speed by judging the weld puddle size — in relation to the joint thickness — and keeping the arc on the leading edge of the puddle.
Stickout is the length of unmelted electrode extending from the tip of the contact tube. Changing the stickout — which occurs with variations in the distance of the contact tube to the workpiece — causes the voltage and amperage to vary, as well as changes the shape of the weld bead.
Generally, maintain a stickout of 1/4 to 1/2 in. Note that when starting a weld, a short stickout helps ensure a good, hot start; a longer stickout — once you've established the arc — can help bridge a gap when encountering poor fit-up. [Note: Long stickouts promote poor starts.] For critical welds, maintain a constant stickout.
More Practice
To make a sound weld, you must learn to combine the mechanical techniques noted in this article into one fluid welding motion. Practice so that welding on all joints in all positions becomes second nature.
For more information on Miller Electric and its MIG welding products, call 1-800-4-A-Miller (1-800-426-4553) or visit the website at www.MillerWelds.com.
Miller's 142-page Gas Metal Arc Welding handbook provides a comprehensive, yet easy to read, explanation of the GMAW, or MIG, process. It contains detailed instructions on how to set up MIG equipment, set MIG variables, select the correct shielding gas, welding techniques, safety, and troubleshooting. Cost is $25. Call Miller at (920) 751-2120 and ask for publication #151 682, Gas Metal Arc Welding.
Old 09-01-2003, 05:41 PM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
Hey Kevin you should put this in theKnowledge Base it could help alot of folks. Me for one, Thanks
Old 09-01-2003, 09:19 PM
s15laynrubba's Avatar
www.s10v8.com
I actually bought their "student package" for $25.00. It comes with some calculators and i think 13 books. Very good reading material.....Jay
Old 03-30-2011, 02:41 PM
Your correct good.info Miller does a great job helping us sell machines to the public. Miller and lincoln have great information on their websites. And hopefully your local distributor will spend time.with you too. ESAB. makes a easy grind wire for.body shop use you may like to try that sometime its a little more bit works great.
Old 03-30-2011, 09:22 PM
Crosley's Avatar
Wiki Edits: 1659
Read the dates on threads when you 'search'
You posted to a 7 yr 6 month old thread
Old 03-31-2011, 05:32 AM
deadbodyman's Avatar
Wiki Edits: 11
I'm glad you posted this ,I wasnt around 6yrs ago.a good read
Old 03-31-2011, 07:34 AM
cyclopsblown34's Avatar
Colorsanding painter
Ditto what Deadbodyman typed.
Old 03-31-2011, 07:52 AM
Wiki Edits: 27
more welding info
in my welding binder I have a copy if the miller Tig hand book I downloaded and printed. Brian Martin here on HR ( Martinsr) has also written a lot of good welding Info on Mig. I also printed some info by Ron Covell from "Tig Welding for Street Rods. " I also get blurbs from the "Welding Tips and Tricks" welding site. some of the Utube welding stuff from other places is junk, some is good.
Old 03-31-2011, 09:31 AM
evolvo's Avatar
Heathen
http://www.youtube.com/watch?v=ZJSaN...layer_embedded
A pal of mine bought one of these. I gave him a hard time for buying this "sissy" welder! We used it for the first time yesterday, it really works well. Wish I had one!!! (I've been mig welding for years)
Old 08-26-2011, 06:39 AM
Originally Posted by evolvo
http://www.youtube.com/watch?v=ZJSa...player_embedded
trying to find same one in my location.. that's really what i need
Old 08-26-2011, 08:09 AM
I see they addressed the often missed but very important subject of wire stick-out but like 99% of the other texts I have seen on the matter they failed to mention tip to nozzle clearance. The wire stick-out, which is extremely important when welding body sheetmetal, simply can not be gauged if the tip location is not considered. For example the recommended 1/4" to 1/2" changes drastically if the tip is recessed 1/4" or more as compared to a tip that is flush with the nozzle or even slightly extended. I personally have always preferred to have the tip extend about 1/16" past the nozzle lip but most recommendations is either flush or very slightly recessed, whichever method is chosen the stick-out should be measured from the tip and not the nozzle lip.
