I wipe mine off with a rag and sometimes I use a scraper..
OMT
Use a much stronger magnet (Cobalt or ceramic, you can pick them up at surplus shops) wrapped in a thick canvas rag (anything that isn't very thick will just rip)
I wipe them with a rag....
Sha, That's an age old question. I usually just use a rag to wipe around them in one direction to bunch up the junk in one spot to make it easier to remove. "There just ain't no easy way"- Seriously a magnet is just that a magnet and there is no way to make it let go of what it is holding unless it is an electro magnet that can be turned off.
What about wrapping them with wax paper and using that shipping tape with threads in it to hold the paper on?
I know it wont help with welding splatter but I would think it would work well for shavings and metal grinding dust... Dumb idea? I usually use a rag too... |
Actually a fellow might wish to put his magnets in a sandwich baggy..that way he can just peel of the baggy and have a clean magnet..heavens it just may work..!!!
OMT
I have one of them round magnets on a stick for picking up stuff
(the official fat guys tool) any how i took a piece of aluminum and made a shield that slides over it with a steel pop rivet to hold it on while its empty other than that KEEP YOUR MAGNETS AWAY FROM METAL FILINGS SR66
"SlowRide66" "Illegitimis non carborundum" Don't let the bastards grind you down! Crankshaft Coalition Master List of Hotrodding Forums |
Anything you put over these will affect their holding power and affect their accuracyplus burned plastic stinks. Use a rag to wipe the crud to one end and pick it off with your fingers. I have a piece of flat strap over my bench I store them on. B
low the spatter off the iron before you put them on and again before you remove them and place on the strap, not the bench
| Recent Garage - Tools posts with photos |
| Welding info | Kevin45 | Body - Exterior | 10 | 08-26-2011 08:09 AM |
| "Basic of Basics" Welding - How do I repair body panels? | Centerline | Body - Exterior | 29 | 06-18-2009 06:54 AM |
| welder reccomendations? | rally4x4racer | Garage - Tools | 32 | 10-14-2008 09:00 PM |
| Question on Mig Welding - HOW to | modas | Body - Exterior | 43 | 12-31-2005 09:48 PM |
| Welding Books | Magnus_Jager | General Rodding Tech | 6 | 11-29-2005 03:57 PM |
