welding panels - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2006, 10:56 PM
rolandag2's Avatar
welding panels
i welded a roof patch on my car and i lap welded with piece of sheetmetal underneath and the patch had 3/8 holes drilled an inch apart on both sides then i welded the seam up not solid but pretty close only some very small spots that are not welded. I have very small metal deflection and heat shrinkage. I will have to use some body filler but i have been told thats normal. I have never done this kind of repair give me some feed back.
http://i54.photobucket.com/albums/g8.../Picture67.jpg
http://i54.photobucket.com/albums/g8.../Picture66.jpg
http://i54.photobucket.com/albums/g8.../Picture71.jpg
http://i54.photobucket.com/albums/g8.../Picture74.jpg
http://i54.photobucket.com/albums/g8...Picture075.jpg
Old 10-10-2006, 04:56 PM
raidmagic's Avatar
Last journal entry: Engine going back in the Hudson.
I've never done that kind of repair either but it looks good to me. If you don't go to thick with the bondo it should be ok. Hopefully one of the smart guys can see this and help you.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
Welding info Kevin45 Body - Exterior 10 08-26-2011 09:09 AM
welder reccomendations? rally4x4racer Garage - Tools 32 10-14-2008 10:00 PM
Parasol Metal body filler. x711 Body - Exterior 16 02-14-2006 10:47 AM
Spot welding panels / seamsealer / rust pigman Body - Exterior 2 06-24-2005 09:12 AM
