welding in patch panels need help - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-13-2011, 10:53 AM
66SSImp454's Avatar
Justin
I have used a blow gun to cool it and a wet rag. The wet rag always left behind moisture making for bad welding after. The blow gun is much better (this is my preferred way to shrink metal also) but you should not have to cool it either way if you take your time and spot weld a little at a time.
As far as the original question. I would just try to weld the gap shut and copper pipe does not have to be on the inside, it will still work you have it outside and weld to it. Or you can make a flange.
Question about welding in qtr patch panels. ck 2 Body - Exterior 21 11-06-2008 05:04 AM
Stick (smaw) Welding for Patch Panels--Need help from old timers...! vtcruiser60 Body - Exterior 52 08-31-2005 10:26 AM
Question on welding patch panels? sled51merc Body - Exterior 39 01-30-2005 12:56 PM
Patch Panels ARPEE Body - Exterior 2 08-17-2004 11:35 PM
Welding in patch panels Maverick Body - Exterior 15 02-01-2003 06:32 PM
