welding in patch panels need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2011, 09:14 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Hey guys Im welding in patch panels on my project &I have about an 1/8 in gap in one spot any ideas how to fill it?
Old 08-25-2011, 09:31 PM
Rag top bird's Avatar
Hot rods are still the king
I take and cut a piece to fit that area and weld it in like the rest of the panel
Old 08-26-2011, 11:53 AM
two cups of tea
Wiki Edits: 2
Its so small I cant really get it in there its about the size if 2 tooth pics side by side &half the length of one.
Old 08-26-2011, 04:30 PM
Something that size I just weld it shut. Make small little welds and let the previous weld completely cool naturally before making another weld. Fills like that take me a long time to do. I usually do them while I'm working on something else...I'll make a weld, go off and work on something else on the car, and come back and make another weld when I'm thinking about it.
Old 08-26-2011, 05:40 PM
two cups of tea
Wiki Edits: 2
Thanks right before I read this I did a search on here &found the same info pretty much,it works great!Thanks
Old 08-26-2011, 09:00 PM
Last journal entry: '27 roadster quarter panels from scratch
Find a piece of scrap copper pipe and pound the end flat with a hammer. Hold it up behind your panel and weld the gap shut. The welding wire won't stick to copper. It works great!
Old 08-26-2011, 09:22 PM
two cups of tea
Wiki Edits: 2
Thanks Ill try that but Im welding patches in the bottom rockers&theres no way to access the back of em.
Old 08-28-2011, 06:21 PM
Old trick that works for me is to use pieces of coat hangers. I shape about 6 inches in the form to follow the lines of the panel and hold onto whats is left over. I place the formed piece in the gap and spot it in place and then form and insert the distance of the gap, spotting as I go. I then go back with wet rag in hand and continue spotting and cooling until the gap is filled. If you think it is getting too hot take a break and trade out the water for fresh, cool stuff.
Old 08-29-2011, 11:54 PM
put up or shut up
I do the coat hanger thing at times. I always grind off the coating first, and will always go over it again welding hotter. Once I've established metal in the gap even though it's porous here and there I go for the biggest and lowest bead I can get.That way when you grind it down you're not in for surprise.
Old 09-03-2011, 02:09 AM
you're much better off to let it cool naturally rather than shrink it with a cold rag.
Old 09-03-2011, 04:52 AM
I agree with that. If you are concerned about distortion, then slowly preheat the panel before welding, and after welding let it cool naturally.
Also the use of coat hanger for welding rod substitute is questionable because of the content of the coat hanger. It could leave the weld more prone to cracking. Any welding shop has cheap welding rod in various thicknesses
http://www.tempil.com/admin/files/Li...0Treatment.pdf
These are pages from a book, so you have to read each page from left to right, even if the first column starts under a picture
Old 09-03-2011, 12:11 PM
Olcarguy's Avatar
Last journal entry: 52 Chev Panel Baskett Case
Hey guy's check this forum out. All you'll ever need to know about patching and more......
Old 09-03-2011, 04:09 PM
put up or shut up
exactly. A wet rag will just force it to shrink too quickly and distort. I always just skip around and feel it by hand. I do sometimes blow on it but it's after it has almost cooled all the way down naturally. The tell all sign is how it looks when you grind on it. If you test the waters even slightly you'll have a hard time to making the weld disappear cause it will be slightly distorted really close to the weld. If you take your time you have no big warpage you can feel with your hand nor will you have that slight warpage that makes it hard for the edges of your weld to disappear when grinding. That's the key to making it disappear and having confidence that it's penetrated well. Obviously that includes a well penetrated weld.
Old 09-04-2011, 07:57 AM
Olcarguy's Avatar
Try that link again
http://www.metalmeet.com/forum/index.php
Old 12-13-2011, 05:29 AM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
I just cool it with the blowgun.
Question about welding in qtr patch panels. ck 2 Body - Exterior 21 11-06-2008 04:04 AM
Stick (smaw) Welding for Patch Panels--Need help from old timers...! vtcruiser60 Body - Exterior 52 08-31-2005 09:26 AM
Question on welding patch panels? sled51merc Body - Exterior 39 01-30-2005 11:56 AM
Patch Panels ARPEE Body - Exterior 2 08-17-2004 10:35 PM
Welding in patch panels Maverick Body - Exterior 15 02-01-2003 05:32 PM
