Welding pistons - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2011, 05:00 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
Welding pistons
There are several engines here for which there are no high performance parts, like some Fiats, Toyotas, Datsuns, etc.
Most have dished pistons, and since we here are at 6.600 feet of altitude a little more compression would make them come alive.
I was thinking of TIG (heliarc) welding the dishes to build up material and raise the compression ratio of them.
Also I have tought of welding up the combustion chambers, some are of cast iron so a nickel rod would be needed for them, The aluminun heads can be TIG welded easily.
BTW... how about doing the same to the SBC heads?
Any toughts..?? old timers must have done something like this in the early hot-rodding years I'm sure.
Old 07-09-2011, 05:27 PM
jonahb's Avatar
I have welded cast pullies off rock crushers successfully with lots of
uniform preheat (500 degrees) checked in multiple places with a laser and
the wax markers and post heat in an oven while slowly decreasing or use fire
resistant blankets. I use Lincoln 99 Ni stick electrodes (smaw) because
it can be machined. I would suspect that cylinder heads would be similar but
I would consult someone who has done this before or have a set of junk
heads and trial and error.
I would be very very cautious welding aluminum pistons because there can
be brittle and soft spots unless you can heat treat them somehow. I think
milling the heads would be easier than welding the combustion chambers and
pistons.
Old 07-09-2011, 05:33 PM
Augusto's Avatar
thanks for the input, about milling the heads, it don't always work, for example in a 60's Land Rover 4 cylinder engine you'll need to mill about 0.250 to get a 8.5:1 CR, imposible to do.
Old 07-09-2011, 05:38 PM
Augusto's Avatar
no problem with the weldings I have like 30 years of experience in welding.
Old 07-09-2011, 05:57 PM
I have one answer for you....................SUPERCHARGER!
No, make that two...................TURBO!!!!!!!!!!
Old 07-09-2011, 06:01 PM
Augusto,
Pistons are cast units so there will be other elements in the mixture.
They can be welded BUT the heat will cause them to not be round. And the pin bosses might become misaligned. Also the top ring groove will be distorted. Lastly how will you get all the pistons to weigh the same and have the same amount of dome?
I think there is a lot to consider other than welding pistons.
I think I would put a turbo-charger or a super-charger on the engine rather than try to do the compression things.
Just my thoughts.
Scholman
Old 07-09-2011, 06:05 PM
Cant weld cast pistons
Billet pistons can be welded. Drag racers do it often. Durability for everyday use may be a problem.
Old 07-09-2011, 06:08 PM
jonahb's Avatar
Originally Posted by scholman
Augusto,
Scholman
Ditto on what scholman said, also what about about the shrinkage when you weld on them also.
Old 07-09-2011, 06:23 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Have you considered casting your own pistons?? Casting aluminum can be done if you are willing to do it..
http://www.alloyavenue.com/vb/content.php
Good place to start..Not every one has access to all the high tech stuff..
Good luck
Sam
Old 07-09-2011, 06:31 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
A comment was made about preheating. There several types of steel (among other metals) that do require a certain preheat before they can be welded then must be allowed to slowly cool. If have an extra cast piston laying around give it a try. What's it going to hurt? Every time I see one of your posts you're always experimenting with something. Maybe find an old junk engine that isn't good for much any more and try it. Do you have access to a lathe and/or mill?
Old 07-09-2011, 08:51 PM
Augusto's Avatar
yes I have a fairly well equipped machine shop.
we must experiment with weird stuff, we don't have easy acces to performance parts and they can become quite pricey when imported from the USA, and for many brands there simply don't exist, I usually think that we must be here like you guys were back in the 50's when hotrodding started.
turbochargers have been one of my best friends when more power is needed, I used to have this nice 1966 Land Rover 88, I installed a blow throgh turbo over a 1bbl Holey carb, this truck was faster than the 4.3 V6 S10 blazers, I enjoyed it a lot, I regret selling it.
Old 07-09-2011, 08:54 PM
Augusto's Avatar
Good luck
Sam
not casted (yet) but I have adapted all kinds of pistons to all kind of engines, specially in motorcycles and 2 stroke racing karts, I?m not sure if I could machine precisely the pin holes, I wish I had a CNC mill... maybe some day I will
Old 07-09-2011, 10:00 PM
bigdog7373's Avatar
Of course it's fast
Contact wiseco. They make pistons for every application. If they dont have it in stock, they'll make it.
Old 07-09-2011, 10:08 PM
I think your best bet would be welding the heads. Is there a prevlent dime a dozen car in your native land? May be worth picking up a few as test subjects, and playing mad doctor. Muahahaha
Old 07-09-2011, 10:10 PM
Blazin72's Avatar
Wiki Edits: 19
Yep, 11:1 forged Wiseco pistons for an .080 over Datsun 1.5L set a friend of mine back $120 a piece!
After welding pavetim Body - Exterior 13 08-29-2009 08:55 AM
Butt welding vs Spot welding 69ChevelleAddict Body - Exterior 19 05-04-2008 01:47 AM
welding on an oil pan? catfish hunter General Rodding Tech 13 02-01-2007 04:45 PM
welding don alchemy General Rodding Tech 11 09-17-2006 08:45 PM
TIG welding will's53chevy General Rodding Tech 29 12-21-2005 01:38 PM
