Welding Question - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 09-08-2007, 01:37 PM
powerrodsmike's Avatar
Wiki Edits: 161
Originally Posted by PsychoBandito
tig will warp body panels to much though, so if you every want to do body work with this welder mig is the way to go.
BUT if its only fabrication you want to do such as exhasut, i agree that tig is the way to go, but it will be EXTREMELY hard to tig weld your exhasut back onto your car.
I find it much easier to weld body panels with my TIG welder, as the warpage is much less, because you can control the heat WAY better, the resulting weld isn't hard like a mig weld, so you can hammer it flat instead of grinding it.
MIG is much faster, and easier for a novice to learn how to get good welds.
Later, mikey
BE different....ACT normal.
  #32 (permalink)
Old 09-09-2007, 04:08 AM
only people who have no experience warp body panels! tig is the best
  #33 (permalink)
Old 09-09-2007, 07:51 AM
Body panels can be warped with any welding process but properly done either TIG or MIG will work just fine. TIG if done right will produce a better more workable weld than MIG with less warpage, the key words here are IF PROPERLY DONE but that holds true for either MIG or TIG.
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
basic welding question montea Body - Exterior 8 02-04-2005 01:01 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
