Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Welding Question
Old 12-31-2012, 06:06 PM
moroeder moroeder is offline
I assume you are MIG welding. Start on the thickest section, watch the molten pool and move the pool over to where it reaches out and pulls itself onto the thinner. The trick is watching the pool moving forward while you are staying in line with joint. You need to learn to watch two or three things at the same time. Pool size, pool location and welding line. You will get use to it after some practice.
