Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Welding Question
Old 01-01-2013, 10:29 AM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
I run the heat for the thicker..If your to cold, You won't have the right penetration for the thicker metal.. It will be a little hotter on the thinner metal.. But if your working off the thincker metal.. You will be ok.. Turn it down for the thinner metal, And you may not get the penetration needed for the thicker metal..
