Welding Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2011, 01:56 PM
daveh's Avatar
Welding Question
Ho Guys,
When I weld 2 pieces of steel together when they are at a 90 degree angle and I can only weld on the inside how can I grind my weld down to smooth/neaten it up? Is there anything special that I can use? Thanks
Dave
Old 07-29-2011, 02:15 PM
A long-nose die grinder works great for this and the cheap one at HF is a really good buy, it uses the same motor assembly as the 4 1/2" angle grinder that has such a good reputation and the chuck runs as true as any grinder I have ever used.
Old 07-29-2011, 03:01 PM
daveh's Avatar
Would it be under a different name? I couldn't find it at Harbor Freight's web site. Thanks
Old 07-29-2011, 04:15 PM
This one, on sale for $35 but usually on sale in the store for $29 and eligible for the coupon discount. This is a very useful tool for more than just welds and this particular one is the only cheap die grinder I know of that runs true enough to use a carbide burr without damaging it, it runs as smooth as the old, much more expensive, Metabo I replaced with it. Most cheap die grinders, air or electric, have so much run-out in the chuck they will literally beat the teeth off of a carbide burr which can easily cost a lot more than the grinder!
http://www.harborfreight.com/electri...aft-44141.html
Old 07-29-2011, 07:41 PM
ajbcc2's Avatar
Last journal entry: frankenstude too
welding question
if tig welding..then just careful heat and flow will get you a nice bead.. I have a mig and if i get too much on an inside weld...#1 a die grinder and if I can get in there..#2 a 4 1/2" grinder with a .040" thick cut off wheel that is almost worn out so it has a small dia. use the cutting edge and carefully shape your bead into shape...
Old 07-29-2011, 07:47 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
My welds are so pretty I dont want to grind them down
Old 07-29-2011, 08:17 PM
ajbcc2's Avatar
weld question
hahah I wish mine were...mine are semi pretty after grinding..l
Old 07-29-2011, 08:21 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Here are some bits that will fill the bill, not suggesting the company just relating the pictures. Hope you have good penetration cause you will be weakening the joint removing metal.. But you knew that.
http://www.heavydutystore.com/die-gr...ts-c-1683.html
Old 07-29-2011, 10:10 PM
35terraplane's Avatar
welding
pepi; That's what she said. couldn't help myself. But you knew that.
Bob
Old 08-01-2011, 09:04 AM
daveh's Avatar
Awesome guys I appreciate the advise. Thanks
welding question wanabuildarod Garage - Tools 4 09-27-2008 09:32 AM
Question on Mig Welding - HOW to modas Body - Exterior 43 12-31-2005 10:48 PM
welding question fennerford General Rodding Tech 3 01-12-2005 09:51 PM
Question on POR-15 and Welding unstable Body - Exterior 3 01-21-2004 01:57 PM
Welding question Studenate Body - Exterior 3 02-04-2003 09:12 PM
