Welding Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2012, 11:24 AM
daveh's Avatar
Welding Question
Hi Guys,
I'm new to welding but I'm getting pretting good at it, mainly when I'm welding the same gauge metal to the same gauge metal.
My questions is what do I do when I want to weld a thin piece of steel to a thicker piece of steel? I seem to be burning through the thin stuff. Thanks and happy new year.
Dave
Old 12-31-2012, 01:51 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Start your arc on the thick side and run the bead to the thin side and lift.. Little tacks will do it..
Sam
Old 12-31-2012, 05:06 PM
I assume you are MIG welding. Start on the thickest section, watch the molten pool and move the pool over to where it reaches out and pulls itself onto the thinner. The trick is watching the pool moving forward while you are staying in line with joint. You need to learn to watch two or three things at the same time. Pool size, pool location and welding line. You will get use to it after some practice.
Old 12-31-2012, 05:37 PM
Wiki Edits: 27
copper back up
Copper back up will absorb the heat on the thinner material. I got a couple pieces of good copper flat stock at the metal recycler about 3/16 thick, to clamp under the weld area. also a few pieces of 1 in copper water pipe to hammer to match contoured places. I also have a can of heat absorbing putty to shape and stick near the weld area. I the old days it was made with asbestos, and you could mix water back into it, the new stuff is asbestos free, but is harder to remix the water back into it.
Old 12-31-2012, 05:39 PM
life is a temporary assignment
Always work off the thicker metal..
Old 12-31-2012, 05:56 PM
Wiki Edits: 27
welding tips.
I signed up to a site called welding tips and tricks.com. I get a free on line video each week about 10 minutes, and Jody has a lot of info. He evaluates a lot of products and also trys to sell some of his stuff.
Old 12-31-2012, 06:00 PM
Wiki Edits: 27
tig pulse
My lincoln tig has a pulse feature, I can set it to pulse at a high amperage to make a good bead, , then drop down to a lower setting to keep from burning thru, but not let the fire go out. then pulse back high for good penetration. repeat . etc.
Old 12-31-2012, 10:34 PM
daveh's Avatar
Thanks guys I'm using a MIG Miller 211 230V setting it according to the chart on the side.
Old 01-01-2013, 09:12 AM
bondo's Avatar
Ayuh,... As noted above, run yer bead off center, towards the heavier piece, 'n whip the puddle over to the thinner material as ya work the bead along...
Old 01-01-2013, 09:22 AM
S10xGN's Avatar
Gotta love a turbo!
Which heat setting, for the thicker or thinner piece? Or somewhere in the middle?
Russ
Old 01-01-2013, 09:29 AM
I run the heat for the thicker..If your to cold, You won't have the right penetration for the thicker metal.. It will be a little hotter on the thinner metal.. But if your working off the thincker metal.. You will be ok.. Turn it down for the thinner metal, And you may not get the penetration needed for the thicker metal..
Welding Question ggassert Garage - Tools 32 09-09-2007 07:51 AM
Welding Question HotRodMan Engine 10 09-17-2006 05:01 PM
Welding Question bluesman123 Body - Exterior 19 11-24-2005 02:18 PM
Welding Question???? Kevin45 Garage - Tools 0 03-11-2004 01:57 PM
Welding question Studenate Body - Exterior 3 02-04-2003 08:12 PM
