Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Welding Question
Old 11-20-2005, 08:24 PM
oldred oldred is offline
Blues, Just make sure that your ground is on the part you are welding on and you will be ok. It is very much possible to run into problems if you, for instance, put your ground clamp on the body and then weld on the frame. In a situation like this if you are welding at fairly current and the body to frame ground is poor you could burn up a lot of things including the whole car! If you are grounded to ANY part and welding on another you need to make sure that the current is running through a good ground and not your wiring or some other critical component.
