Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Welding Question
Old 11-22-2005, 03:18 PM
firebird_red firebird_red is offline
The key is correct placement of the ground clamp. If you run welding current from the exhaust pipe, through the engine back to various ground connections, it won't help much that you disconnected the battery. The ground needs to be next to the welding so the current flow path isn't through the engine electronics.
