welding really close to curtain bags - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2011, 09:16 AM
put up or shut up
I will unplug the battery and give it a good 30-40 min to drain any residual currents but should I unplug the curtain bag harness as well? I wouldn't think so but I just want to make sure. Here's some pics. In one of the pics you can clearly see the curtain bag and how close it will be. The seam is right above the curtains and that's where I'll be plug welding.
Old 09-14-2011, 11:01 AM
Simply remove the bags, you can drop the whole thing down leaving the wire plugged in or just unplug them and have the code cleared later.
Old 09-14-2011, 03:19 PM
Old Fool's Avatar
Will it throw a code if the battery is disconnected and residual is drained off?
My 2004 Tahoe does not throw srs codes if done that way. Just do not power it back up until the bags are plugged in on the Tahoe.
Old 09-14-2011, 06:23 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
Why not glue the side and the back edge of headers and just weld at glass openings?
Old 09-14-2011, 07:16 PM
That isn't following manufactures recomendations but you are very right, in the real world bonding the sides is the best way to go.
Old 09-14-2011, 09:44 PM
put up or shut up
Yeah, I'll do that. They'll stay plugged but hanging. Thanks.
Funny...every part taking the headliner out was really easy except those darn little hooks for the sun visors, which was the smallest part to come off. Go figure.
How close is too close for proximity of exhaust manifold to polyurethane bushing grobb284 Engine 0 04-13-2009 05:44 AM
timing marks How close is close enough dirtinla Engine 3 11-25-2008 09:00 PM
Butt welding vs Spot welding 69ChevelleAddict Body - Exterior 19 05-04-2008 01:47 AM
Behind the Cheddar curtain bbcwgn Introduce Yourself 4 11-28-2006 05:41 PM
welding close to body filler ? jcarter Body - Exterior 5 01-10-2005 09:28 PM
